Old 06-14-2005
drpfeffer drpfeffer is offline
Senior Member
drpfeffer is an unknown quantity at this point
Sonar 4 - send each track to mixer..
Hey guys..
I am using sonar 4 with an m-audio delta 66 interface, and i have been out recording some tunes live with 4 microphones, and now i want to send each track via the outs on my audiointerface to my mixer so i can try to mix them out of the box..
But S4 wont send the tracks mono, it seems.. the ony options i have in the track output to: dialog is delta 66 1/2, 3/4 etc..
Does anyone have a solution to this problem, or is it impossible..?
Old 06-14-2005
mathieujohnson mathieujohnson is offline
Junior Member
mathieujohnson is on a distinguished road
pan each track, number one and two will be one-left two-right
so every track you can send seperate by choosing your output as lets say a mic one thats vocals or i don't know what you recorded, so mic one goes to output 1/2 but by panning it left, it will only go out on channel 1
do the same left-1 right-2 left-3 right-4 and you'll get your 4 outs
i guess you are using wdm drivers, if you had asio you probably could send mono tracks, or maby its in the configuration of your soundcard, don't know if there is a mono switch though.....but my trick should work fine!
Old 06-14-2005
Senior Member
thanks i'm gonna try the panning right away, btw i am using ASIO drivers, so maybe i should take a look at my soundcards control panel too..
Old 06-14-2005
Senior Member
thx.. worked out fine..
Old 06-14-2005
punkin's Avatar
punkin punkin is offline
Univalve & Avatar Speaks
punkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond reputepunkin has a reputation beyond repute
SONAR will send them mono when you get it set up...I agree with drpfeffer in that it is likely a setup with your audio card. The 66 should set up very similar to my 1010 which depending upon which drivers and how you have them enabled, you'll get either or both 1/2 stereo or 1 left 2 right.
She's not the boss of me
can I use a 24 track mixer as many separate preamps? frego Digital Recording & Computers 5 03-10-2005 12:08
Confused, in need of help? Benreturns Newbies 56 11-06-2003 04:02
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
4 Track and 14 Channel Mixer hook up. Scooter B The Rack 4 01-25-2003 07:34
Tascam 4 track to Behringer mixer? Michaelyu5 Recording Techniques 5 01-28-2002 20:09
