Old 06-08-2005
cellardweller's Avatar
cellardweller cellardweller is offline
Subterranean Sovereign
cellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond reputecellardweller has a reputation beyond repute
MR8 midi interface?
I've never looked twice at it before, but doesn't the MR8 have a place for a midi cable to be plugged in to it?
Has anyone ever used it?
I wanted to try something.
I was going to try running the drum machine part (zoom RT323) through my Sans GT2, and the bass guitar programming on the drum machine through the GT2 also.
I can route these through seperate outs, but how do I sync them up later?
Presumably with a midi connection... right?
How complicated is this?
Anyone attempted anything similar?
Old 06-08-2005
BentRabbit's Avatar
BentRabbit BentRabbit is offline
Drumb & Drumber
BentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond reputeBentRabbit has a reputation beyond repute
Unfortunately it's a Midi Out only...
It works well for synching your click track with other outboard equipment, or with another deck... The MR8 has to be the MTC Master because of it's Midi Out only status...
Essentially, I run from it to the the Midi In on my VF 16 when I want to transfer more than two tracks between the decks... The Midi Time Code insures that all the tracks start and stop at the same time...
If you don't hear what the mix is telling you, you shouldn't be working on it in the first place. - John Scrip, Massive Mastering
Myspace Page
Old 06-08-2005
So IF the drum machine has midi in, will it not sync with the MR8 on a second track? (Say for instance, drums already tracked on MR8, then a second time to sync the programmed bass with the recorded drum track)
This is all new to me, bear with me !
Midi and Creamware dangerman MIDI Mania 3 05-18-2005 00:53
Midi Interface decision the blues daddy Cubase User Forum 1 02-28-2005 07:16
New midi system cableing RICK FITZPATRICK MIDI Mania 4 06-16-2002 11:24
Midi Interface via USB = latency? ::: Badtz MIDI Mania 5 05-23-2002 11:53
Midi and PSR 330 Gumbylives Recording Techniques 0 07-04-2001 18:24
