Old 06-07-2005
Idgeit's Avatar
Idgeit Idgeit is offline
Dedicated Member
Idgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to behold
.Wav export
Hey all,
Im trying to figure when ever i export to wav from sonar it dosent seem to come up as a regular format, anyone know of any exporting plugins or anything to fix this?
Thanks
- Idgeit
"Lets go with the milk....", "Lets go with the milk?", "Im sorry, could you bless me with some of your precious milk?" - Ricky, Trailer park Boys
Old 06-07-2005
Jeyan's Avatar
Jeyan Jeyan is offline
Force of Nature
Jeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond reputeJeyan has a reputation beyond repute
what do you mean it doesnt come as regular format, check your options while saving. You might have ended up with a some weird preset by mistake.
JJeyan
Old 06-07-2005
Idgeit's Avatar
Dedicated Member
when i save and try to burn it ect, it says its not a valid file type.
Old 06-07-2005
Jeyan's Avatar
Force of Nature
The possibilities are
1. your sample rate or bit rate may be different. Make sure when you save, you save in 16bit 44.1 Khz
2. save it in windows pcm wav format (I believe that is what the default is)
3. Use good software like Nero full version to burn your cds.
Lets see if any of these helps you.
JJeyan
Old 06-07-2005
minofifa's Avatar
minofifa minofifa is offline
1K Silver Member
minofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond reputeminofifa has a reputation beyond repute
that is strange. did you try selecting a different type under options when you export? did you remember to dither down to 16 bit if you are putting it on a CD (cause 24 bit won't work).
if that's not working, you could try something like i have set up. I have a tool that allows you to take files out of sonar and plug them into another program, in my case cool edit. once i bounce my final mix to track, i export that track to cool edit, do some last minute wav editing, and use cool edit to export it as mp3 or .wav, whatever tickles my fancy. if you would like that program to link the programs, i can send it to you.
www.sanijav.com
www.myspace.com/sanijav
Old 06-07-2005
Idgeit's Avatar
Dedicated Member
thanks for the offer but i got it working , all i had to do was change it to 16 bit and all the problems have stopped. thanks for all your help guys
- Idgeit
Export Audio Irritant Rockenheimer Cakewalk / Sonar Forum 5 06-08-2005 14:56
Export .WAV files on 2488 problem bpb TASCAM User Forum 3 06-17-2004 07:37
Cakewalk Homestudio4 won't import my .wav files ultrajosh Cakewalk / Sonar Forum 10 06-07-2004 11:55
CD-R players and .wav files 63falcon Cakewalk / Sonar Forum 5 01-11-2004 11:38
SONAR: Export to .wav vs. Outboard Mastering Gear mark4man Cakewalk / Sonar Forum 23 01-06-2004 19:25
