Comparison of CWPA 9 and Sonar...how do i combine?
Ok, I miss the combine feature of CWPA...
how do i combine in sonar? the reason i ask is that you used to be able to combine and choose poly/monophonic and i miss that. maybe there is another way to do it since Sonar is nondestructive. but i am basically wanting to do things monophonically for punches and bounce to track simply mixes them together--not my desired goal. secondly, how do i cut muiltiple tracks and segments? in CWPA, you'd simply go into a view (i forget the name of it) by double clicking the selected tracks you wanted to edit and you could use the cut tool for multiple tracks at once. How do i do this? the cut tool doesn't seem to do much-- lastly (for now ), how can i make it so when i hit stop, the cursor stops there instead of jumping back to a marker? I have searched the settings and man, none of them seem to fix it.Thanks soooo much for all the help!!!!! |
in otherwords, when parts of tracks overlap, the first one stops and the overlapping one starts. essentially like punching in audio (the overlapping replaces the original) thanks again for the help, this was the easiest of the three for me to circumvent, i just wanted a simpler way than what i'm doing (slip editing the parts i want out) |
perfect, thanks for all the help!
| Sonar 4.......some questions | Magnum | Cakewalk / Sonar Forum | 25 | 07-15-2006 11:27 |
| MTC and sync problems with Sonar and Akai DPS16 | PhillipT | MIDI Mania | 3 | 01-12-2005 14:50 |
| Just an idea for Sonar.... | Still' Dreamin' | Cakewalk / Sonar Forum | 10 | 08-14-2002 16:11 |
| SONAR Locks up! Help! | Aaron Cheney | Cakewalk / Sonar Forum | 4 | 01-16-2002 16:40 |
| SONAR XL Quickie Review... | UncleThumpy | Cakewalk / Sonar Forum | 16 | 04-01-2001 10:17 |
