Old 05-19-2005
logan logan is offline
Junior Member
logan is on a distinguished road
tracking without preamp??
say if you want to record a vocal without a preamp would you loose any quality in your vocals if you patched them into the preamp and back into the computer after you record?
sir... the mics not the problem......
Old 05-19-2005
Track Rat's Avatar
Total Gear Slut
No preamp, no vocal. Microphones need a preamp to get their signal up to line level to input to any recording device.
Mike
Old 05-19-2005
HogansHiro's Avatar
HogansHiro HogansHiro is offline
Now with 25% more sarcasm
HogansHiro will become famous soon enough
Are you talking about NOT using an outboard pre-amp and just using your board pres?
Mr Behringer's illegitimate child. He backwards engineered me from a better kid. I hate you dad!!
Old 05-20-2005
acorec's Avatar
acorec acorec is offline
Banned
acorec has a spectacular aura aboutacorec has a spectacular aura aboutacorec has a spectacular aura about
Are you talking about not using a pre-amp when recording and patching a pre-amp in, like say back to a computer, after you record? Or did you mean something else that makes sense?
Old 05-20-2005
corban's Avatar
corban corban is offline
Registered Boozer
corban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond repute
so to summarize, you need a preamp, the preamps in your board will work, but putting them back through a preamp after you record is worse than useless
Old 05-20-2005
northsiderap's Avatar
northsiderap northsiderap is offline
Dedicated Member
northsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of light
Mic without preamp
Even if your dynamic mic put out a very healthy signal of 3mv, it would still be sitting at -50dBv to -70dbV at best for useable passages. Say your recorder's noise level is -100dBv. That leaves you 30-50dBv from the bottom of your signal to the noise floor.
Now, run this back through a mic preamp and you only have a noise floor reduced to -30dbV to -50dbV. Most good mic preamps are spec'd far better than -100dbV for a noise floor. You just took your noise floor up from -100db to -30db.
Ouch
Old 05-20-2005
Alexbt's Avatar
Alexbt Alexbt is offline
Force of Nature
Alexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond reputeAlexbt has a reputation beyond repute
Sounds like they mean putting a XLR to 1/4 (and adapted from there) into their computer and cranking up the gain afterwards...
Recording Setup:
Power Mac G4 / M-Audio Delta 1010LT
1Ghz | 768MB RAM | Mac OS 10.4.5
160 GB Internal | 250 GB Ext. USB 2
Yamaha MG10/2 Mixing Console
Logic Express 7, Cubase SX & Deck 3
Keyboard Rig:
Kurzweil SP88 / Kurzweil PC2R w/O / Yamaha TX7
Old 05-20-2005
HogansHiro's Avatar
It'd be a hell of a lot easier to figure out if he checked his damn thread.
Old 05-20-2005
Dedicated Member
Reglr Snd Crds
If it's a Soundblaster or some standard computer card, it has a mic in already. That means there's a functional mic preamp in the card. Why would you need two mic preamps? Sounds bad with 2.
Standard computer sound cards are not bad... I'm sure there's someone competent out there designing them. You can get good stuff with a 1/4" to 1/8" adapter and a microphone.
Old 05-20-2005
fraserhutch's Avatar
fraserhutch fraserhutch is offline
Flypaper for freaks
fraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond reputefraserhutch has a reputation beyond repute
Define "good", please.
Sure, they may be someone competent designing them, but generally they are designed for supporting gaming and recording Aunt Lizzie's Christmas message. They are not generally designed for decent audio recording.
My $0.02.
The fact that no one understands you doesn't mean you're an artist...
Old 05-20-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
They are not designed at all for pro audio recording purposes and nowhere near "good enough".... as someone pointed out, they're usable for games and the family Christmas message, but not much else...........
  #12
Old 05-21-2005
Junior Member
sryy
hey sry what i meant was i have preamps on my board and on my presonus firepod and i have and presonus m80. but what i was asking is if i had a vocalist taht came in and sung a song directly from the mic into my board using its pres and then into me presonus and record. later could i go back and run what i allready recorded through a friends focusrite preamp and then re record it back into my computer would i still be able to get the tone and sound quality of that focusrite or not?
  #13
Old 05-21-2005
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
... directly from the mic into my board using its pres and then into me presonus and record.
That's already two preamps in a row?
edit; Oops I missed the 'Firepod so scratch that..
... later could i go back and run what i allready recorded through a friends focusrite preamp and then re record it back into my computer would i still be able to get the tone and sound quality of that focusrite or not?
For the focusrite preamp or for some other process?
From your first post it would seem that you were looking for a way to record without a pre so as to not lose whatever initial quality there was.(?) Then the generally true short answer would be definitely not. a) When in doubt, the shortest path is a good place to shoot for. b) Wouldn't whatever small gain a better pre offers be whipped out by 'inferior pre, not to mention another trip through converters?
Wayne
Just for the record, you can run mics w/o a pre (in the right conditions) but how 'bout we get the big things worked out first.
  #14
Old 05-21-2005
Enzo Polotso Enzo Polotso is offline
Junior Member
Enzo Polotso will become famous soon enough
you've got a firepod (so do i), forget your board, the firepods got 8 very usable pres built in, probably better than your boards (unless you've got a really good one), just go mic>XLR cable>firepod>computer. if you really wanna use the pres in your board, you'd go into the channel 1 and 2 INs on the BACK of the firepod, make sure you dont go from those pres to the front firepod XLRs.
game set match
  #15
Old 05-21-2005
SouthSIDE Glen's Avatar
SouthSIDE Glen SouthSIDE Glen is offline
independentrecording.net
SouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond reputeSouthSIDE Glen has a reputation beyond repute
One ping, and one ping only
Logan,
No.
A preamp is to be used only once. To boost the voltage from the microphone to bring it to "standard line level" voltage so that it looks to your mixer, recorder, etc. like any other line signal. Once you're at line voltage, that's it. No more preamps.
G.
Glen J. Stephan,
SouthSIDE Multimedia Productions
RECORDING RESOURCES AND INFO SITE:
  #16
Old 05-22-2005
Theros's Avatar
Theros Theros is offline
Senior Member
Theros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond reputeTheros has a reputation beyond repute
This thread is confusing...
I thought what he was asking was if he could record MIC->Computer and save that track (yes its not at line level)
Then later run that track from PC->PRE->PC so he could basically run it through a diffrent PRE laters (His friends), using the recorded non line level track...
Don't think thats possible anyhows... signal would be to weak to record?
Could possibly have mis-interpretted his meaning anyhows...
Theros
Cabling Preamp to SoundCard Couloir_KW Newbies 16 02-23-2005 12:32
preamp > preamp? MemoGtr Newbies 8 02-22-2005 09:26
Preamp Consumer Dilemma. Simmons The Rack 11 07-02-2003 09:57
preamp question joedirt Recording Techniques 5 02-11-2002 22:38
preamp vs. dynamic mic jungkang Microphones 7 08-02-2001 21:10
