Old 05-19-2005
walters walters is offline
Force of Nature
walters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond reputewalters has a reputation beyond repute
Stereo imaging
Recording Keyboards and guitars in stereo
Does the processors use alot of panning to do this?
How does the processors get stereo imaging from a mono source?
Is there any Post Production tricks or tips for more stereo imaging effects?
what are some good tricks to take a mono signal and make it stereo
like the HAAS effects or ADT effects or Inverting phase on one channel
with added reverb?
Old 05-19-2005
corban's Avatar
corban corban is offline
Registered Boozer
corban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond reputecorban has a reputation beyond repute
Walters has more posts than me.
Old 05-19-2005
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Hello, walters. Hope this finds help in you. Pardon my english. Poor it can be.
Spiacente per le domande dumb, ma io vorrebbe sapere perchè le cose non sono mentre sembrano sulla superficie. "perchè sono le cose non il senso sembrano?" è una domanda che la gente di desiderio di I _ così _ farebbe più spesso di. La maggior parte della gente sembra smettere di notare che le cose non sono il senso che sembrino e cominciano comportarsi come se quel le apparenze siano tutte che importino. A me che è l'essenza di quella forma della morte spiritosa che noi in questa chiamata "età adulta della società." È perchè credo che soltanto ai bambini dovrebbero essere permessi votare o possedere la proprietà -- ma venendo a mancare quello, ci dovrebbe essere una legge (o migliorare ancora, un accordo generale) quella grown-ups deve rispondere a tutte le domande oneste onestamente. Allora forse non saremmo una tal coltura di inganno e di self-deception e la gente mantennrebbe la loro capacità di notare le cose che non hanno il significato. Le risposte da Sean e da Scott sono punto sopra, ma vorrei provare a aiutarli a visualizzare che cosa questi due tipi di microfoni stanno facendo. Di nuovo, le categorie relative sono "trasduttore di pressione" (basicamente omnidirezionale) e "trasduttore di pendenza di pressione" (basicamente figure-8, ma usando i diaframmi doppi ed altro inganna, qualunque altro modello direzionale di prim'ordine può essere sintetizzato compreso cardioid ed eccellente o hypercardioid). Il modello di un trasduttore di pressione è un barometro. Misura la pressione d'aria nello spazio intorno esso. Il più semplice, barometro di scienza della grado-scuola è un barattolo di latta sigillato con aria in esso. Il coperchio della latta fletterà in proporzione ai cambiamenti di pressione d'aria nella stanza intorno esso; potete fissare un bastone al coperchio e calibrate i movimenti del bastone in termini di che cosa unità di pressione d'aria desiderate usare (pollici di mercurio o dell'unità metrica standard, che è "barre"). La cosa è, la latta otterrà compressa aumentando la pressione d'aria o si espanderà in tempo di pressione d'aria bassa, senza riguardo quale al senso "lo mirate". In effetti il concetto "di mirare" un barometro realmente non esiste perché è integrante e rispondente ad un fenomeno che è interamente intorno esso. Lo regolate appena in su in che cosa orientamento fisico è conveniente per voi e funziona. Potreste pensare alla pressione barometrica in un rapporto quotidiano del tempo come essendo la risposta del barometro a 0,000011574 hertz se desiderate (un ciclo al giorno). Essenzialmente un barometro è un microfono con la risposta giù a CC e quella è una caratteristica nell'ambiente dei trasduttori di pressione: la loro risposta a bassa frequenza può essere basso lontano esteso come gradite. La maggior parte dei microfoni di pressione hanno certo piccolo sfiato integrato per impedirli lo scoppio una volta trasportati da aria, ma possono molto bene essere completamente piani inferiore a 1 hertz o a 5 hertz, certamente a qualsiasi frequenza udibile.
I won the internets......
Old 05-19-2005
earworm's Avatar
earworm earworm is offline
it might be true...
earworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond repute
you're laughing at me , right?
...listen...
Old 05-19-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
Dogman, you rock!
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 05-19-2005
ez_willis's Avatar
ez_willis ez_willis is offline
Virtual Ninja
ez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond reputeez_willis has a reputation beyond repute
Sorry to have to do this to you wally, but it seems almost impossible to avoid at this point.
An essay on stereo imaging
In this essay I will consider the social, economic and political factors of Stereo imaging . At one stage or another, every man woman or child will be faced with the issue of Stereo imaging . While it has been acknowledged that it has an important part to play in the development of man, there are just not enough blues songs written about Stereo imaging . It is an unfortunate consequence of our civilizations history that Stereo imaging is rarely given rational consideration by socialists, whom I can say no more about due to legal restrictions. Here begins my indepth analysis of the glourious subject of Stereo imaging .
Social Factors
Society is a simple word with a very complex definition. When Sir Bernard Chivilary said 'hounds will feast on society' [1] he saw clearly into the human heart. While the western world use a knife and fork, the Chinese use chopsticks. Of course Stereo imaging is crunchy on the outside but soft in the middle.
Did I mention how lovely Stereo imaging is? It grows stonger every day.
Economic Factors
Our world is driven by supply and demand. Of course, Stereo imaging fits perfectly into the Maiden-Tuesday-Lending model. For those of you unfamiliar with this model it is derived from the Three-Amigos model but with greater emphasis on the outlying gross national product. Inflation
Stereo imaging
There is no longer a need to argue the importance of Stereo imaging , it is clear to see that the results speak for themselves. The question which surfaces now is, how? Even a child could work out that inflation looms over Stereo imaging this cannot be a coincidence. Strong fluctuations in investor confidence have been seen over the past two financial years.
Political Factors
Politics was once a game featuring competitors from elite classes. Politicians find it difficult to choose between what has become known in politics as - 'The two ways' - night and day.
One quote comes instantly to mind when examining this topic. I mean of course the words of jazz singer Augstin Skank 'Political idealists must ideally deal, for I daily list my ideals politically.' [2] This clearly illustrates the primary concern of those involved with Stereo imaging . I feel strongly that if politicians spent less time thinking about Stereo imaging and put more effort into their family life, that we would have a very different country.
Why did Stereo imaging cross the road? - To get to the other side! Just my little joke, but lets hope that Stereo imaging doesn't inspire similar hilarity in the next elections.
Conclusion
In my opinion Stereo imaging has a special place in the heart of mankind. It questions, brings glamour to an unglamorous time and most importantly it perseveres.
I shall give the final word to star Ozzy Paltrow: 'My Daddy loved Stereo imaging and his Daddy loved Stereo imaging .' [3]
[1] Sir Bernard Chivilary - Interestingly... - 1904 Badger Books
[2] Skank - Politics for Dummies - PV6 Media
[3] Your Stereo imaging - Issue 43 - Never Ever Publishing
Originally Posted by 60's guy View Post
You win.
Old 05-19-2005
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Dogman and Willis seem to have it down. Answer nonsense with nonsense!
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 05-19-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
with added reverb?
Yes........
"That was so terrible, I think you gave me cancer!"
My tunage
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
What do you mean nonsense? Do you have any idea how long these essays take to write, not to mention a lifetime worth of experience that goes into them.
You win.
Old 05-19-2005
Dogman's Avatar
And, yes willis, I read every word of every essay I have found. My head is so full of info, I better just go take a dump. Thanks.
Ed
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
Ed
Hope it helps! Too bad you don't have a laptop, you could read my
Essay on effective bowel relief
In this essay I will consider the social, economic and political factors of effective bowel relief. Advancments in effective bowel relief can be linked to many areas. Remarkably effective bowel relief is heralded by shopkeepers and investment bankers alike, leading many to state that it is important to remember that ‘what goes up must come down.’ Inevitably effective bowel relief is often misunderstood by those politicaly minded individuals living in the past, who are yet to grow accustomed to its disombobulating nature. Relax, sit back and gasp as I display the rich tapestries of effective bowel relief.
Social Factors
While some scholars have claimed that there is no such thing as society, this is rubbish. The immortal and indispensable phrase ‘honesty is the best policy’ [1] failed to understand that if one seriously intends to 'not judge a book by its cover', then one must read a lot of books. While deviating from the norm will always cause unrest amongst ones peers, effective bowel relief is quite good.
Recent thought on effective bowel relief has been a real eye-opener for society from young to old. It grows stonger every day.
Economic Factors
Economics has been defined as 'I'll scratch your back if you scratch mine.' To my learned ear that sounds like two people with itchy backs. Of course, effective bowel relief fits perfectly into the Custard-Not-Mustard model, which I hope will be familiar to most readers. Interest
Indisputably there is a link. How can this be explained? Of course interest plays in increasingly important role in the market economy. In the light of this free trade must be examined.
Political Factors
Much of the writings of historians display the conquests of the most powerful nations over less powerful ones. Politicians find it difficult to choose between what has become known in politics as - 'The two ways' - the two sides of effective bowel relief.
To quote a legend in their own life time, Demetrius Bootlegger 'Man's greatest enemy is complacency with regards to personal and political hygiene.' [2] I couldn't have put it better my self. When it comes to effective bowel relief this is clearly true. If our political system can be seen as a cake, then effective bowel relief makes a good case for being the icing.
The question which we must each ask ourselves is, will we allow effective bowel relief to win our vote?
Conclusion
To reiterate, effective bowel relief is, to use the language of the streets 'Super Cool.' It inspires, puts out 'fires', and is a joy to behold.
As a parting shot here are the words of super-star Britney Kournikova: 'My Daddy loved effective bowel relief and his Daddy loved effective bowel relief.' [3]
[1] Traditional - possibly first said by King Arthor... but probably not.
[2] Bootlegger - Take It! - 1961 Viva Books
[3] Everything you always wanted to know about effective bowel relief, but were afraid to ask. - Issue 287 - QKS Publishing
....while doing your thing.
You win.
  #12
Old 05-19-2005
Dogman's Avatar
Man, thanks willis. You just saved me. I needed an article like this. I'll print it off, and a few "extra" pages, and be off for some reading.
Willis, you are the man.
Ed
  #13
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
I'm starting to think that wally enjoys my essay essays so much that he keeps posting to keep getting more essay essay? What do you give say wally wally, wally like willis essay essay?
You win.
  #14
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
Oh man, that's grade AA work right there! I give it the willis stamp of approval, and I fucking hate willis! Ooops, sorry for the bad word wally wally.
You win.
  #15
Old 05-19-2005
Dogman's Avatar
Dude, I'd give you some rep if it would let me. It won't, so I'll just say, FUCKNFUNNY!!!!
  #16
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
I'm feelin' yer love.
There's some fodder for ya wally.
fod·der
n.
1. Feed for livestock, especially coarsely chopped hay or straw.
2. Raw material, as for artistic creation.
3. A consumable, often inferior item or resource that is in demand and usually abundant supply: romantic novels intended as fodder for the pulp fiction market.
You win.
  #17
Old 05-19-2005
true-eurt's Avatar
true-eurt true-eurt is offline
Mrs. Hyde
Location: Loving the imperfect is the perfection of love
true-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond reputetrue-eurt has a reputation beyond repute
with added reverb?
I will not be able to give you any answers....but perhaps I can figure out what you are trying to say...
In the "Stereo" recording process of Keyboards and Geetars, must one use a lot of Panning with Processors?
How can/does the Mono Source give Stereo Imaging Effects to the Processor?
Is it possible in Post Production to get more Stereo Imaging Effects?
Anyone have any Tricks or Tips for accomplishing this?
Any good tips for turning Mono Signal into Stereo Signal like the HAAS effects, or the ADT effects?
Or Inverting Phase on one channel with added Reverb?
I think I just may have made it worst... Well I tried.
SpankSHED songs
I may be off my rocker but I'm still on a roll
EurtSongs
  #18
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
Personally, I prefer your crude-ass ways, but I'm like that.
You win.
  #19
Old 05-19-2005
true-eurt's Avatar
Mrs. Hyde
There are no words, oops, I just said them.
SpankSHED songs
EurtSongs
  #20
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
_________________________________________________________________
You win.
  #21
Old 05-19-2005
ez_willis's Avatar
Virtual Ninja
Blowout sale, bwahaahaaaa!
You win.
  #22
Old 05-20-2005
ez_willis's Avatar
Virtual Ninja
Thank you walters. Thank you for not picking *richards*, or *rogers*, or *harolds*, or *pickles*, scratch that, pickles I could probably work with, but thank you for not picking the others, for I have hours of enjoyment in my future.
You win.
  #23
Old 05-20-2005
Force of Nature
Dame you guys over took this thread into a whole new area
and level thanks alot
  #24
Old 05-20-2005
earworm's Avatar
it might be true...
KOTSWINKEL
whahahahahhahaha, rolling over the floor !
...listen...
  #25
Old 05-20-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
No different than the whole new audio area your posts go to.........
tascam 788 stereo imaging issue? musicmonster TASCAM User Forum 4 01-31-2003 15:13
Question for BlueBear about stereo Boray Newbies 4 01-29-2003 15:53
How panning of stereo tracks works - Did you know you only shrink the stereo field? Boray Roland, Boss, VS Series Forum 2 01-29-2003 11:09
Stinking In Stereo Matthew Walsh Mixing / Mastering 8 10-02-2000 03:43
Stereo or Mono for guitar and bass tracks? JLLFAN Newbies 1 11-23-1999 11:27
