Old 05-18-2005
johnny j johnny j is offline
Newbie
johnny j is on a distinguished road
compressing overall mix
i dont know if im in the right section for this advice i need but no doubt you'll let me know
i have a yamaha MD8 and were ready to transfer some songs onto a regular MD player, from this i'll put it onto a CD. there are inserts for tracks 1 and 2 which are hooked up to a compressor. we generally put vocals on track 1 and any toher tracks that are a bit weak we move to track 2 and use the compressor to boost the volume a bit
i have a second compressor lying idle so what i thought id do is to put a compressor in line between the MD8 and the MD recorder. however ive been reading a book on recording techniques and it seems to say that this method isnt a good idea. it did say if possible to "compress through the stereo bus" (i think that was the wording) but i dont know how to do this. at the rear of the unit theres a stereo out and a monitor out so i cant see how to compress the whole thing
can anyone advise on how to compress the overall sound, is it necessary even? any thoughts gratefully received to a newcomer
Old 05-18-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
I used to think that compressing the whole mix was a must to get that gelled "as one" sound, but i have realised that it is the mixing that acheives this gelled sound. So i dont bother compressing my mix. I cant really hear a difference in the uncompressed to compressed anyway!!
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 05-18-2005
RhythmRmixd's Avatar
RhythmRmixd RhythmRmixd is offline
Dedicated Member
RhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond reputeRhythmRmixd has a reputation beyond repute
That's the idea, at least if you're compressing it correctly. Of course, if you don't trust your ears to understand the difference then that's a different story all together....
Old 05-18-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
Ooooh! Ow! And I'm not even a Scotsman!
Old 05-18-2005
Dedicated Member
Now, now. I wasn't trying to be critical. Don't start stirring the kool-aid.
Old 05-18-2005
ecktronic's Avatar
Question
So your saying the point is not to be able to hear a difference. So why do it then!!!!!!!!!
CRYSTAL MIXING
MY BAND
Old 05-18-2005
Dedicated Member
Well, yes and no. To somebody who understands (and I'm not saying I'm an expert on this in any way) how compression works, how the attack, release, ratio, etc. control the punchiness and pumping type effects, then they will know if what they're doing is helping or hurting the original signal. When I said you shouldn't be able to hear the difference, I meant you shouldn't actually be hearing the compressor itself working as the material is playing. The difference should be subtle enough so the compression improves the sound, but not so it's noticeable. And any Joe Schmoe (someone who doesn't mix music) listening to the mix in their car stereo wouldn't notice anyway, cause they wouldn't know what compression sounds like in the first place!
A good experiment would be to overcompress something you've mixed, and listen to whats going on. Then bring the overall compression level down, and listen to how it changes the sound.
Old 05-18-2005
ecktronic's Avatar
RhythmRmixd, do you think that a plug-in like Waves R-comp could actually produce an effect of more punchiness on a mix? ( to a decent degree)
I understand what a compressor does and how it works with the attack and release times.
CRYSTAL MIXING
MY BAND
Old 05-18-2005
Inspired Inspired is offline
Senior Member
Inspired is on a distinguished road
So how do you put compression on an entire mix? Specifically using Cakewalk's Sonar 2.0XL...
Old 05-18-2005
Dedicated Member
I don't have experience with the Waves Renissance stuff, but I imagine any compressor, used properly, could add a bit of punch on an overall mix. And, of course, different compressors alter the sound in different ways. I used a software multiband compressor on a mix the other night to one of my rap/hip hop instrumentals, and was doing an A/B comparison with it on/off while the mix was playing back. It was noticeably better with it on (I think I'm finally getting the hang of this!), but not TOO noticeable. It cleaned up my mids and highs and seemed to give that area a little more clarity, which is something in the past I didn't think a compressor was used for. I guess the point is, don't over-do it, because no compression is better than too much compression any day of the week, IMOO.
Old 05-18-2005
Chibi Nappa Chibi Nappa is offline
Force of Nature
Chibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond reputeChibi Nappa has a reputation beyond repute
Let's back up to this for a second... Why are you sticking an MD player in there? You know MD players use lossy data compression, right? You're hurting your sound.
  #12
Old 05-18-2005
ecktronic's Avatar
Ive never used Sonar, but im guessing that you would import your stereo mix to a stereo track and any plugins that you add on that chanel will effect it.
CRYSTAL MIXING
MY BAND
  #13
Old 05-18-2005
grn's Avatar
grn grn is offline
www.michaelchagnon.com
grn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond repute
have you asked yourself... what is the purpose of this? if it already sounds good, don't try to fix it. why are you compressing it? do you want it louder? you should use compression as an effect to make an instrument sound better and more even, but not to make anything louder/gel together.
Michael Chagnon
Twitter
MySpace
  #14
Old 05-18-2005
ecktronic's Avatar
Cheers RhythmRmixd, i put up two samples for folk to try and work out which one is compressed and which one is not compressed. Should be a bit of fun. I made sure the volumes were pretty much the same so that nothing apart from the compression effect could affect folks judgement. My ears arent trained enough yet but im sure i can hear a difference in the mix with compression. The thread is in the MP3 section. You can also just click on my link at the bottom.
CRYSTAL MIXING
MY BAND
  #15
Old 05-18-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
1. putting it in the chain the way you intended will work, and be the same as "compress through the stereo bus". same thing.
2. 2:1, quick attack, quick-to-medium release, 3 db of gain reduction = ballpark
3. no it is not necessary. it is an effect like eq.
  #16
Old 05-18-2005
ecktronic's Avatar
That is practically the settings i used for my samples at the link at the bottom excpet for 3dB gain reduction. Why reduce when you obviously want to make up the gain lost from compressing?
2=ballpark??!!??!! no comprende.
CRYSTAL MIXING
MY BAND
  #17
Old 05-18-2005
FALKEN's Avatar
= ballpark means these settings should put you in the ballpark. if you do not reduce than you are not compressing anything!! so you put 3 db of gain reduction, and 3 db of makeup. comprende?
  #18
Old 05-18-2005
ecktronic's Avatar
Ah so you mean those settings will give 3dB of gain reduction, so you have to add 3dB of gain so as not to get any sound degredation. What about the threshold, surely it has alot to do with how much the gain is reduced?
CRYSTAL MIXING
MY BAND
  #19
Old 05-18-2005
FALKEN's Avatar
exactly. start with those settings and adjust the threshold until you have 3 db of gain reduction. my bad. should have said that.
if your'e trying to sound like green day or something really in your face, set it for 12 db of gain reduction and play with the release. heh, heh.
  #20
Old 05-18-2005
mixsit mixsit is offline
Been Here, Posted That
mixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond reputemixsit has a reputation beyond repute
2. 2:1, quick attack..
Caution flag (for newbies )
'Quick attack? (Ask how quick.) To quick = no transients. = Playing in a soggy ballpark.
Wayne
  #21
Old 05-18-2005
FALKEN's Avatar
different settings for different sounds right? too slow will actually make the music MORE dynamic... whatever sounds cool man.
  #22
Old 05-18-2005
ryanlikestorock ryanlikestorock is offline
Force of Nature
ryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to beholdryanlikestorock is a splendid one to behold
I'm always confused when people reach for a compressor to get "more punch". By definition, the effect of compression is "less punch"... to limit the difference between peak and average level. Mix bus compression more than 1db is going to just kill the mix and less than 1db is used mostly just for colour anyway. If you have a nice colourful compressor, just set it to compress .5db for colour... otherwise you're probably just making things sound worse.
Use a compressor if you hear a problem in the mix because of too much dynamic range. Otherwise, leave it be.
Ryan A. Mills
Little King Studio
Joao Carvalho Mastering
  #23
Old 05-19-2005
ecktronic's Avatar
Some good words ryan. I could never really see the point in compressing the whole mix, but i heard it was done quite alot, so i tried and didnt get the results i was expecting. It did pickle my head for a bit trying to work out how a compresor could possibly give more punch to anything.
CRYSTAL MIXING
MY BAND
  #24
Old 05-19-2005
northsiderap's Avatar
northsiderap northsiderap is offline
Dedicated Member
northsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of lightnorthsiderap is a glorious beacon of light
More punch anyone?
I figure if you set the attack long enough you should get a BIGGER dynamic range because of the increased audible ratio between the start of the note and where the compressor kicks in and squashes.
I also compress the final mix if I am looking for a ducking-like effect, where either the vocals or bass drum squash the rest of the mix. It's kinda nice to bus out a track, EQ it, and run it back into the sidechain so the compressor is working on only certain frequencies. It's fun to play with... Listening to each kick drum, vocal, or cymbal splash eat up the whole mix.
Sometimes its necessary to compress when there are passages where one or all of the instrumentalists freaks out and increases the dynamic range beyond the point of reasonable listening. Have you ever listened to a classical station, only to find yourself turning it up... and up... and up.... and then BAM quick, turn it down!
The noise floor makes it unreasonable to let the dynamic range sit at such a high level. Perhaps some classical stations assume that the listeners want the music untouched, or that they are sitting in a perfectly quiet room with their $1,000,000 stereo system.
  #25
Old 05-19-2005
Dedicated Member
I think this is entirely dependant on what you are trying to do with the mix. A lot of people today argue that commercial music is over-compressed, over-limited, whatever, especially with pop, rap, etc. A bit of overall compression, especially on hip-hop beat, can really help push the song along and add feel to it (but definitely not to be over-done). Just because a compressor isn't used in traditional ways or by definition doesn't mean the sound created by it is always undesirable.
Public Mix Contest #2!! xfinsterx MP3 Mixing Clinic 370 09-05-2004 12:45
EQ, compressing - in what order? BootCut Mixing / Mastering 37 11-16-2002 07:54
Worst commercial mix you've ever heard? MIX CRIMES Alchemist3k Mixing / Mastering 69 10-03-2002 22:00
Monitor Volume vs Mix Accuracy DDev Mixing / Mastering 3 09-17-2002 00:10
Compressing during Mix Down sober918 Roland, Boss, VS Series Forum 1 11-21-2001 16:44
