ADAT Error 5
I just installed a second-hand (maybe third- or fourth-) blackface ADAT and it produces Er-5 whenever the tape rolls. According to the manual this is a drum alignment issue. Could this have resulted from shipping, or is that unlikely?
The machine also won't format a tape. Gets to the "data" portion...and then the "play" light blinks, the entire machine freezes, and I have to power it down. Has anyone experienced these symptoms before? I got a good deal on the unit, obviously not so good if it turns out to be DOA... |
That unit definitely requires servicing..........
bruce valeriani recording articles http://www.bluebearsound.com/images/bb_siglogo.jpg |
Err 0 - Faulty Tape Load or Eject Try loading again. If N/G, reinitialize.
Err 1 - Tape did not pull properly from cassette Try another tape (tape may be defective). Err 2- Tape didn't thread to "disengaged" mode Try again, otherwise loading system problem. Err 3 - Tape didn't thread to "engaged" mode Reinitialize, otherwise possible load system problem. Err 4 - Rotary Head not spinning Reinitialize, otherwise possible drum motor problem. Err 5- Drum Speed to Fast/Slow Make sure "Digital In" is not pressed when not used. Err 6 - Did not load data from head of tape Make sure BRC was turned on AFTER ADAT's. Err 7 - Bad write sector(s) Clean heads. If N/G, may be worn heads and/or bad or worn tape. Err 8 - Sync lost, tape will stop Possible bad sync cable. Use only ALESIS cables. Err 9 - Capstan spinning, tape won't move Broken tape? Try another. Possible bad idler wheel and/or pinch roller. ADI flashing- "Flashing dot". Dirty heads Clean heads properly (recommend dBm2705 Cleaning Kit). ALSO see Er 7. DU - Unit has condensation on or near heads DO NOT LOAD A TAPE! Leave unit on a few hours to let dry. Full - Serial Buffer is full Reinitialize. Possible bad idler wheel or sync cable. Prot - Cassette's write tab has been removed Check cassette. If tab has NOT been removed, poss. bad write protect switch. NOFO- Unit cannot verify formatted tape Possible worn heads, poor alignment/calibration, worn/bad tapes, cleaning. |
Got a refund, thanks for your replies.
| Integrating an ADAT into a digital audio/sequencing workstation | anppilot1 | Alesis Forum | 1 | 11-26-2003 19:26 |
| Adat Edit And Purchasing An Adat | Hmurray | Alesis Forum | 17 | 04-06-2003 08:45 |
| Sync ADAT to Logic Audio 5 via MOTU 828 without BRC | veiledsaber | Alesis Forum | 0 | 06-29-2002 20:58 |
| PCR CARD Time Sync and Alesis ADAT | Fangar | Digital Recording & Computers | 0 | 12-26-2001 01:05 |
| Track Seperation | Big E | Recording Techniques | 1 | 12-04-2000 15:03 |
