Gain vs. Faders on a Mixing Board
What is the proper technique to use when setting your levels in a live situation. I set the faders to 0 and adjust the gain to get it "in the ball park". I then adjust the faders to find the right volume. Is this the correct method? Someone once told me to set the gain to 12 o'clock and make all adjustments at the faders. This doesn't seem like it would work.
Can anyone straighten me out? |
I start out the same way you do; use the sound check to set the trim with the faders at zero, though I go the extra step with the trim to try to "keep it in the infield" and not just "in the ballpark". I try not to use the faders for that; reserving them solely for for riding the live mix.
G. |
stay away from that person. ![]() |
Hit the PFL on a channel, set the level to 0 on the meters. Use the faders to mix. That is proper gain staging.
| Fostex 812 mixing board for sale (12 channel) | RichardStern | Free Ads for Music / Recording Equipment | 1 | 01-28-2005 12:28 |
| Mixing board. | blackdiscoball | Analog Only | 1 | 11-24-2004 22:40 |
| Mixing board advice? PC recording | bullyhill | Newbies | 7 | 12-10-2002 05:45 |
| Mixing and Volume Faders | Stephen Jones | Cakewalk / Sonar Forum | 6 | 10-30-2001 22:17 |
| mixing board and computer recording | phatstadt | Newbies | 2 | 10-23-1999 12:02 |
