Anyone used a BOKSE SM-1 SMPTE to MIDI Computer before??
Hi there, I'm looking for info on how to operate a Bokse SM-1 (SMPTE to MIDI Computer) or even a manual...
Has anyone even heard of this Bokse SM-1 ot Bokse at all? I can generate code and adjust frame rates etc..., I can hear code out the SMPTE output, I can get it to read SMPTE but there is a slight lag and I'm not sure on the procedure for adjusting the offset. I can't get it to communicate with the computer through midi, I'm not very up to speed on MTC so this is a bit of a grey area for me. The closest I've come is running a midi cable out from the PC into the SM-1 and another cable out from the SM-1 in the PC. when I sey nuendo to external sync, its says "lock 25" (the framerate) and will play. If I unplug either cable it stops playing, but there is no code coming out the SMPTE output of the SM-1 while it does this. Also if I input SMPTE to the SM-1, no MTC comes out the midi outputs. I run Nuendo 2 on the PC but I just bought an old Tascam MSR-16 and want to be able to sync it to the computer. Someone suggested using a software midi analyzer to check the output of the SM-1, but I don't think I have one, can anyone suggest a software midi analyzer? Any help will be very much appreciated. Cheers... |
okay forget it, it doesn't do MTC only midi clock
thanks for looking |
cheers ssscientist ,
MidiOx was how I figured it all out... it is awesome!! Thanks |
No charge then.
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 3 | 10-09-2003 15:59 |
| Need serious midi help whats the best way to do this? | puppethead | MIDI Mania | 0 | 10-08-2003 22:00 |
| Midi drum stuff for the hard of thinking: | Alan McGuinness | Cakewalk / Sonar Forum | 3 | 12-12-2002 12:03 |
| The wrist bone is connected to the hand bone; help with MIDI and USB concepts/setup | f. lai | MIDI Mania | 4 | 07-13-2002 13:55 |
