Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 05-16-2005
eskkes eskkes is offline
Newbie
eskkes is on a distinguished road
drum sound absoprtion
hello,
i am looking for something that isolates the different parts of a drum kit from eachother while recording..
e.g. something is stop the hi hat sound leaking into the snare drum mike.
is there any product someone could recommend...
thanks for any help in advance!
Old 05-16-2005
Supercreep's Avatar
Supercreep Supercreep is offline
Immortalizes Your Member
Supercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond reputeSupercreep has a reputation beyond repute
Only if you want to record all the drum parts separately. So the answer really is no.
Old 05-16-2005
DonF's Avatar
DonF DonF is offline
Call Me "Grandpa"
DonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond repute
If mic selection and placement don't give you enough isolation, you could try something like this: http://www.sweetwater.com/store/detail/DS404
Old 05-16-2005
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
I keep wondering and wondering and wondering and wondering and wondering and wondering where do people get the idea you are supposed to isolate each drum mic?! Where does this idea come from?
If you're painting a picture, do you keep the red seperate from the yellow? Do you keep the blue away from the red? No.
If you're having problems between mics, its either the room's acoustic treatments, mic postioning or the tuning of the kit. If the kit is properly tuned and the mics are in good position, everything should "play nice" with each other. If you have to isolate, you're doing something wrong.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Old 05-17-2005
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
Listen to Phil
I'm totally with SuperCreep and Phil good on this one (even though I stopped wondering along time ago). IMHO- The drum kit as a whole is greater than the sum of it's parts. So treat the drum kit as one instrument rather than separate parts.
That said, one technique that might work for you would be to use a gate on everything which I never really liked to do.
Old 05-25-2005
Venni Venni is offline
Newbie
Venni is on a distinguished road
Angle the snare mic away from hihat pointing to center of snare.
You should clean the leakage on the tomtom Bd and floor tom tracks in your editor after you record. Be careful with Bd. Have backup and Don't overclean
Old 05-25-2005
skipwave's Avatar
skipwave skipwave is offline
Junior Member
skipwave is on a distinguished road
The only instance, IMHO, where added isolation is a valid approach, is the snare batter vs. hihat. Some players like the HH really close to the snare and moving it higher can just make them oh so unhappy.
In this case, you want the most absorbent possible material, totally non-reflective surface, otherwise it will create some weird echo into all the mics facing it. I've been told that fiberglass inside a sock works well, though I fashioned something out of acoustic foam and sheetblok. Just remember to make both sides absorbent, then clip it to gooseneck or boom for positioning.
www.myspace.com/thetrouble
"I want to be champion of the world, or champion of something."
-Duchamp
Alan... No Stephen Paul Mic? DJL Microphones 249 07-27-2007 23:47
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
what's your favorite drum sound? dcptnsdcvd Drums and Percussion 61 01-17-2005 17:10
Live Mixing Problems... MiXit-G Mixing / Mastering 11 04-07-2003 05:17
