Go Back   Home Recording > User Forums by Brand > Sony Tools / Sonic Foundry
Reply    Audiofanzine Sony Sony News Sony Medias Sony Tests Sony Articles Sony User Reviews Sony Classifieds Ads
Old 08-18-2000
mouse_man mouse_man is offline
Newbie
mouse_man is on a distinguished road
Question
i recently bought Acid 2.0 in hopes that it could help to improve my guitar playing. but i quickly realied that i need to be able to record my own loops or else acid won't do anything for me. so, what gear do i need for recording guitar loops? Any recomended mics or sound cards? I'd like to stay in acid for now since i don't really count on going pro anytime soon, but if there is a relatively cheap arranger than acid, i'd like to know. Please respond
leland
Old 08-18-2000
John Sayers's Avatar
John Sayers John Sayers is offline
Solar Power!!
John Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond reputeJohn Sayers has a reputation beyond repute
surely you can record your guitar loops in soundforge!!
Cheers
Old 08-19-2000
Newbie
yea, but i need a mic, and i'm wondering what i should get for under $200, plus whether i need a good sound card. When i wrote "a relatively chep arranger than acid" i omitted saying that i wanted it not cheaper than acid, but better than acid. ie: "a relatively cheap arranger that's better than acid..."
Old 08-20-2000
Solar Power!!
Everyone here says N-Track is a reliable multitracker and it's the cheapest from what I can gather
cheers
Old 08-21-2000
AlChuck's Avatar
AlChuck AlChuck is offline
Been Here, Posted That
AlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond reputeAlChuck has a reputation beyond repute
mouseman,
What kind of sound card do you already have? I'm also assuming you mean electric guitar.
To record a guitar into a typical soundcard, you need some way to get the guitar signal into a line level signal that can be plugged into the Line In on the soundcard.
The "traditional" approach is to use a decent microphone (the most commonly suggested mic for guitar recording is the Shure SM-57, which you can probably buy new for around $80) into a mixer or mic preamp, and take a line level signla from that into the soundcard (you'll usually need an adapter or special cable as most soundcards have stereo 1/8" minijacks for Line In and most mixers or preamps have 1/4" or XLR connectors).
Another approach is to direct inject (DI) your guitar signal -- this means having some device that you plug your guitar into which then outputs a line level signal. Most modern guitar amps have a line out. So do most guitar multieffectors and preamps. You might already have something that can get you such a signal. If not, the simplest way is to use a device called a direct box (typically well under $100). The fanciest way is one of the new crop of amp modeling devices like the Line6 POD or the Johnson J Station (typically about $300 or more).
The standard wisdom is that an ordinary DI guitar track sounds terrible -- lifeless and thin -- and that the only way to get a really good sound is to mic a good amp. But this takes a lot of effort getting the mic placed just right, avoding picking up ambient sounds, having to have the guitar amp loud enough to disturb the neighbors, and so forth. A POD allows you to get a really close approximation by just plugging it in and twiddling knobs, and you can monitor it at any volume. But even a dry, dull, uninteresting DI guitar sound can be improved after the fact with DirectX plugins. Of course, while you're playing it will sound dull and uninspiring, which might affect the quality of your performance (I feel like a deflated tire when my guitar sounds poor).
As far as better software "arrangers" than ACID -- depends on what you want to do. If you want to strictly use audio loops and play against them, ACID might be all you need (and it is killer for this purpose). If you want to be able to record MIDI tracks like drum parts and keyboard parts, ACID won't do you any good at all. If you want to record a four-piece band in real time, ACID won't be much good for that, either. For more general recording and arranging, you need something like Cakewalk, Cubase, Logic, n-track Studio, or one of the many other such programs out there.
-AlChuck
