how best to make SACD-quality recordings?
I bought a 16-bit, 44.1kHz multitracker (a Fostex VF-160) a year ago and naturally only after the fact read about higher-quality 24-bit, 96+kHz multitrackers and formats (SACD and DVD-Audio).
Is it possible for a home recording enthusiast to burn SACDs? (Probably not due at least to the preferable CD/SACD 5.1 hybrid format.) Or would one have to settle for 5.1 DVD-Audio? Can either format be made with a computer DVD burner? Is DVD-Audio compressed/uncompressed? I take it its probably best to upgrade to a *dedicated* computer-based recording setup for dealing with higher-end formats. What would you recommend for recording software? Protools? Would Nuendo do the job? I really don't want to sonically limit my pieces and would like any pushes in the right direction regarding recording for these superior mediums. Thanks in advance, Daryle http://www.soundclick.com/bands/daryleackerman.htm |
SACD really can't be done with home studio equipment let alone most studio equipment. No one really records directly into an SACD format...it's usually done at a really high sample rate (192ish) and then converted....or done in analog and then converted somewhere else at a place that can do it. Same with the bit depth. There is no software program on the market that I know of to record at 2,822,400Hz, 1 bit.
If you'd like a dispute on whether SACD is even important to consider...and if you're interested in the math and can understand it, read this paper: http://sjeng.org/ftp/SACD.pdf
www.redlabaudio.com |
| Mixing secrets by sonusman | s_o_n_u_s_m_a_n | Mixing / Mastering | 261 | 05-14-2009 19:26 |
| How can I make the best quality recording with the most cheap equipments | Juan Francis | Digital Recording & Computers | 3 | 05-02-2005 09:24 |
| Any body knows how to make a mic with the same best quality as known microphones? | Dimetre | Microphones | 35 | 01-13-2004 03:27 |
| How to convert WAV to MP3 at CD Quality..... | NickHall | MP3 Mixing Clinic | 41 | 06-28-2002 12:45 |
| How can I make the best quality recording with the cheapest equipments | Juan Francis | Digital Recording & Computers | 10 | 07-27-2000 01:56 |
