Old 05-13-2005
pheelthemusic pheelthemusic is offline
Newbie
pheelthemusic is on a distinguished road
Help a n00b set up his gear (DP based studio)
Totally new to computer recoding. I have put together what I believe to be a fairly sweet rig. Heres my gear: Apple dual 2ghz G5 w/ 4GBs ram, PreSonus Firepod, M-Audio BX8 Monitors, Juno-D synth, Behringer T1952 tube compressor, other gear not crucial to my setup. I have MOTU Digital Performer 4.52 on my computer. Im having a huge problem figuring out how to succesfully connect all of this stuff within the DP software. The synth works fully in garage band (MIDI) so I know that I hooked that up correctly. However, there is no choice for Juno-D in the model list in the core audio midi setup tool. Is this a problem? If so how do I get around this? WHen I open DP nothing seems to be functioning properly. I can record but I hear nothing out of the mons until I play it back. And this is only after playing around with the inputs and outputs on the software until I get lucky. Definately not correct. The Synth comes up in DP but there are no patches. Similar to the audio when I record I can see the information being recorded ont he computer btu cannot hear anything. With the MIDI however I cant even hear anythign when playign back. Any DP experts out there that can tell me how I should set all this up within DP????? And if the lack of JUno-D in the OSX MIDI setup tool is a problem. THANKS SO MUCH
Old 05-14-2005
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
I use DP, but not for MIDI, so no ideas on that problem, personally. That said, I can offer a couple of suggestions for places to get help on the subject, just in case nobody else has any ideas, either....
There are some DP forums on groups.yahoo.com that would probably be better places to ask this question. I think one is "Digital Performer" and the other is motu-mac or mac-motu or something. The latter requires email confirmation, so you'll know it if you find the right one. Also check out the unicornation board (www.unicornation.com, I think).
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 05-14-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
You need to read the manual. Seriously, all the routing setup procedures are covered really well, the MOTU manuals are some of the best out there in my opinion.
But assuming that you have the routing set up properly, here's one thing to try:
Go to the "Studio" menu and select "Audio Monitor". In the menu bar of the window that comes up you see a little headphones icon. Make sure that is selected.
In the OSX Core Midi application you can set up your own instrument for the Juno-D. So just click on "Add Device". Double click on the new device and select the manufacturer, then type in whatever name you want for the synth. Finally, make sure that the device is connected to the correct midi I/O.
Old 05-14-2005
Newbie
Pretty sure I have audio working now but Im still having MIDI issues through DP. MIDI works awesome through garage band so I know its a DP related issue. ANy advice??
Home studio of a young gear junkie PoetSleep00 Newbies 28 06-10-2006 18:09
Bought Gear based on this Forum malcolm123 Microphones 74 04-03-2006 03:22
PC based studio K54 Digital Recording & Computers 3 05-22-2003 14:56
Advice connecting recording studio gear and home music system Arranger Newbies 1 04-14-2003 20:38
I think I have found the Perfect Studio set up for me. pisces7378 Digital Recording & Computers 1 11-05-2002 09:37
