D4 or Dm5?
is the dm5 just an upgrade from the d4? or is it completely different, and if so, which one is better. Im looking to eventually make an electronic drumset for my studio, and was wondering which would be a better choice, especially on metal songs.
The illest punk band in the world son - www.bobhopepunks.5u.com |
I had the D4 and it was nothing more than a bank of SR-16 samples.
Why would you want to trigger crappy sounds? |
Through the midi out, you could trigger any drumsound in the world with a sampler, be it hardware or software. |
I think Stefan is commenting on the DM4s usefulness as a trigger unit. I do believe that Scrubucket is looking for info on the sounds built in.
I really don't know how to explain my point much easier... just read my above posts again again and maybe somehow you'll get it. |
I own both the d4 and the dm5. I use them both on the same set simultaneously. I know the dm5 has alot more percussion settings if you're into that but I do not honestly hear the sound difference in basics like the large room kit...and the basics drums...snares, toms...aren't discernible form machine to machine.....it may very well be different but like i said I honestly don't hear it.
I own the DM Pro kit. I would imagine the DM5 is something between D4 and DM Pro. Sounds and samples may be the same through all three brains, processing as well, but the tweakability of each sample sound, parameter adjustment, combination of different samples to create your own snare or cymbals or whatever, is quite extensive on the DM Pro...more than I actually use, but I do use some. I would imagine by what I have read that the DM5 is somewhat like this, perhaps less detailed on the parameters that can be edited and the level of editing detail in general.
Scrubucket, if you're wondering what kind of sounds I get out of the DM Pro to tape, likely similar to what you could expect to get out of D4 or DM5, go to soundclick.com and search Dale O'Brien. When you pull up my page, download and play "Wild-Eyed Jim's". There are other songs on my site from a previous band of mine on there too...THESE DO NOT USE THE ALESIS, only Wild-Eyed Jim's. I think I got a rather believable sound out of the thing. Anyway, it will give you a rough idea of what you can expect from an Alesis-controlled electronic kit.
My girl there are just some things that aren't done...like drinking Dom Perignon '53 above the temperature of 38 degrees Fahrenheit |
| dm4 vs dm5 | notbradsohner | Alesis Forum | 0 | 12-05-2004 20:40 |
| DM5 "CRAZy BOOM SOUND" HELP?!?!?!? | badmuthadrumma | Alesis Forum | 0 | 09-10-2004 23:38 |
| Alesis DM5 vs. SR-16 | VooDu Valve | The Rack | 1 | 07-11-2004 08:37 |
| Triggering samples with Alesis DM5... | waverz | Cubase User Forum | 7 | 12-12-2003 10:15 |
| Drum Modules: Alesis DM5? Or other suggestions? | Don Lee | Newbies | 3 | 01-21-2002 15:36 |
