Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 05-11-2005
Chris F's Avatar
Chris F Chris F is offline
Dedicated Member
Chris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond reputeChris F has a reputation beyond repute
Masterlink DSP questions
I've just started recording with my new Masterlink, and I'm very impressed with the unit so far. The interface is taking some getting used to, but overall, I'm very pleased and can see myself using it every day.
About the DSP - there are four different types, and I've used two successfully so far: the EQ, and the Normalization. The EQ worked about like I expected and sounds okay...I'm sure I'll get better with it. The Normalization was pretty simple, but the signal came out a bit hotter than I would have liked. Is there anyway to drop the "ceiling" on the normalization by about 3 or 4 db?
I can't get jack to sound good with the compression, but then I know little about compression. Is this the 3630 compressor? If so, I won't bother with it. If not, any tips?
Last, I've heard a few people on this board say that the Limiter is a real gem, but I can't seem to figure out how to use it properly. If anyone has any tips about how to get started and in the ballpark with it, I'd be very grateful! FWIW, I'm recording duets with either grand piano and double bass, or archtop and double bass, and I'd like to give the recordings a little more presence without jacking the all of the peaks up to -0db. Thanks in advance!
Wherever you go, there you are.
www.chrisfitzgeraldmusic.com
Old 05-12-2005
oboe_prestini oboe_prestini is offline
Newbie
oboe_prestini is on a distinguished road
I'm just curious to know: what recording equipment next to the Masterlink do you use to record the duets?
Old 05-12-2005
PHILANDDON PHILANDDON is offline
Senior Member
PHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud ofPHILANDDON has much to be proud of
I have the masterlink and love it. My understanding of the normalization feature is that it boosts your levels as they can be before clipping. Basically, the feature allows you to see the maximum + gain-change you can do to the song. After you know the maximum change, you can undo the normalizer and boost a more modest amount that suits you're ear by using doing a track level boost using the basic track edit feature.
I like the limiter. I've found that it's good for hot tunes (i.e. with high peaks) that you want/need to make louder. I've played a little with the compressor, but my songs are usually compressed already when they reach the masterlink so I haven't found that feature to be all that valuable. I've used the EQ just to do a tiny bit of bass roll-off here and there.
Old 05-12-2005
Chris F's Avatar
Dedicated Member
Just mics (M-Audio Solaris for bass and either SP B1's or MXL 603's for piano) and pres (M-Audio Tampa and DMP3) through a Soundcraft M12. So far, so good!
PHIL - I figured out that little trick last night, and you're right...it works very, VERY well. Thanks!
questions, questions, questions chronicinsomnia Newbies 8 12-08-2004 18:48
Questions about NWR. TheRealWaldo MP3 Mixing Clinic 8 11-15-2003 18:00
General Questions casey3115 Newbies 4 09-16-2003 08:12
3 serious questions THE BIG PIECE DJ & Hip Hop Production 10 07-11-2003 14:56
Please try the search before asking questions ola Other Equipment and Reviews 5 10-24-2000 02:09
