Old 05-10-2005
RezN8's Avatar
RezN8 RezN8 is offline
Blick-um, blick-um...
RezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond reputeRezN8 has a reputation beyond repute
Preamp as an insert or send???
Is it possible to run a preamp through an insert or aux channel of a mixing board? Are there any disadvantages, aside from the obvious?
I'm getting ready to buy a single channel preamp for vocals, but was wondering if it could also be used on several drum tracks at once by running it through the board like you would with an effects loop.
Thanks in advance for your opinions. -Rez
Old 05-10-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
What do you consider an obvious disadvantage?
To answer your question, if the preamp has a DI input, then you could do this. If it just has an XLR mic input, then you'd have to put a DI between the mixer and the preamp.
This was recently covered in another thread, but the important factor to remember is that the XLR mic inputs are expecting to see signal at mic level, which is approximately -50. Line level signals are around -10 to +4. So you could easily overload the input on the preamp by feeding it line level signals.
It's also important to remember the purpose of a preamp: to take a mic level signal and amplify it to line level. That's why preamps exist. I'm assuming that what you want to do is use a preamp as sort of a color box, like maybe if you have a tube preamp and want to impart its flavor onto some drum tracks or loops.
If you want to use a preamp that way, what you should do is put a DI between the line level signal and the preamp. So you'd take the insert out, feed it to a DI, take it from the DI output to the preamp input, and then return it to the board from the preamp output. Same with using a preamp on the aux sends. If your preamp already has a DI built in (line level input) then you are all set. Many, many preamps are designed with line level inputs these days.
Old 05-11-2005
RezN8's Avatar
Possibly overloading the signal.
Yup, that's where I was going with this. Thanks for your insight!
Old 05-11-2005
Kiauma Kiauma is offline
Senior Member
Kiauma is just really niceKiauma is just really niceKiauma is just really niceKiauma is just really nice
The Tube MP pre has an instrument input with a -20db switch and variable input gain AND output gain, which should accomodate a very wide signal level. The users guide says it will accept line level inputs, and is suitable for a "Direct box". The Studio model, which is about $70 new, also has a clip limiter and VU meter. The pre may even add the type of coloration you are looking for. I have one and I really like the sound.
Old 05-11-2005
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
A DI inout would certainly work, but what you really want is a line input. You can always try it through the mic inout if you want, just go slow and watch the meters and listen carefully. Maybe a little fuzz is even what you are after
Preamp Consumer Dilemma. Simmons The Rack 11 07-02-2003 09:57
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
preamp vs. dynamic mic jungkang Microphones 7 08-02-2001 21:10
Need info on best way to hook up Patchbay Infinitrax The Rack 2 03-09-2001 02:42
Send and Insert Effects barrykaf Cubase User Forum 1 10-31-2000 23:52
