Old 05-09-2005
RichardPitt RichardPitt is offline
Newbie
RichardPitt is on a distinguished road
Bizarre Yamaha AW16G Problem
It's odd but despite everthing possible being panned dead centre, my AW16G seems to be outputting EVERYTHING with a noticiable bias to the left channel.
Any ideas why? (this problem seems to have developed recently)
Old 05-09-2005
Kevin Deschwazi's Avatar
Kevin Deschwazi Kevin Deschwazi is offline
Brittunculus
Kevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond reputeKevin Deschwazi has a reputation beyond repute
Duff right output from AW16G? Duff cable going to the right speaker? Duff right speaker? Duff right ear? (stranger things have happened ).
Old 05-09-2005
Newbie
Indeed, but the problem seems entirely internal as you can clearly see the discrepancy between channels on the level meters
Old 05-09-2005
ssscientist's Avatar
ssscientist ssscientist is offline
Info you can use...
ssscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond reputessscientist has a reputation beyond repute
There is a row of 5 knobs immediately over the ch 15/16 fader, and the bottom one is for pan/balance.
What probably happened is you pushed the master fader button, then brushed/twisted/cranked this bottom knob to the left. Selecting the master fader by pressing the button and turning the light @ the top of the fader orange, then twisting the knob back to C should solve the problem.
Old 05-10-2005
dgatwood's Avatar
dgatwood dgatwood is offline
is out. Leave a message.
dgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond reputedgatwood has a reputation beyond repute
Another possibility (without knowing this particular mixer) is trims. Most mixers have them, usually right above the jack where you plug in the cable. These can be used to micro-adjust the levels of input signals to calibrate the 0 VU point for each input. Tweak as needed.
Originally Posted by Obi-Wan
If you mod me down, I will only grow stronger.
Old 05-10-2005
Newbie
Aw16g
Hey Guys, thanks for the replies.
Everything is defintely panned centre. Input levels are normal. It's only with output & monitoring levels that this problem occurs. Can a machine of this type develop a physical fault that would cause this to happen?
Old 05-10-2005
60's guy's Avatar
60's guy 60's guy is offline
9th most annoying poster
60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute60's guy has a reputation beyond repute
Richard,
I own an AW16G also. I tried to replicate your situation by calling up a song in which I used all 16 tracks. I set all the pannings to center and when I monitored the stereo buss the overall L & R levels were fairly uniform showing an occasional boost toward one side or the other. If that is what you are witnessing I wouldn't be overly concerned with it.
You say that you see a noticeable bias to the left channel. How much greater is it compared to the right channel and is it constant?
If it is constant then there's a chance that your machine needs some sort of calibration. Unfortunately, the manual doesn't have a trouble shooting section.
I'd be interested to read anything further you discover.
Using outboard FX with Yamaha AW16G lo beam Recording Techniques 5 10-15-2003 04:57
Fostex VF16 or Yamaha AW16G Jamie Jukosky Recording Techniques 14 02-17-2003 13:18
Yamaha Keybaord Problem Cal D Keyboards and Sound Modules 1 11-15-2002 05:25
MMC with Yamaha AW16g and Sonar? Grabber Other Equipment and Reviews 1 11-07-2002 14:46
Yamaha AW16G Jarbarian Newbies 2 11-02-2002 15:59
