Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-08-2005
Accolade Accolade is offline
Newbie
Accolade has a little shameless behaviour in the past
How Do I Unleash My Mic's Full Potential?
Alright so I just got a rode nt1 with a studio projects vtb1 preamp. Now the mic is great. But I can't get it anywhere to sound as amazing as it can. My former mic was a dynamic mic and that's pretty much all I know how to mix. I don't even know how to approach condensors. I use Cool Edit but I also have Cubase and Sound Forge among others. What should I do. Right now I'm just doing dynamic processing and reverb with normalization. It sounds good but not nearly as good as it can. My friend uses the exact same step up but his shit sounds about 1,000 times better. I'd ask him but he is on tour right now and I really don't have a way to contact him. How should I approach this? I'm lost I really need help.
Old 05-08-2005
NYMorningstar NYMorningstar is offline
Recording Modus Operandi
NYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond reputeNYMorningstar has a reputation beyond repute
The difference could be simply the room you are recording in. Try using different rooms or acoustically treat the room you now use. Get the sound right to begin with and you won't be needing effects and processing.
Old 05-08-2005
Newbie
there isn't another place i can put it. any other suggestions?
Old 05-08-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
I have that mic and preamp. Fist off, I would recommend that you don't normalize a vocal track, ever. Second, how are you approaching the gain staging with the VTB-1? The SP page (http://www.studioprojects.com/vtb1.html) gives a decent description of how to do this if you scroll down to "For best tube-sound results." I never turn the toob up past about 1 o'clock, because it get's really ugly if you do. Make sure you're not clipping anywhere along your signal chain.
The room, as previously mentioned, becomes increasingly important with condenser mics. The NT1 is very sensitive and will pick up reflections if you don't treat the room. Hanging heavy blankets on the walls and/or on mic stands around where you are tracking will help some.
If you have a sound clip, we could perhaps give you more specific pointers.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 05-08-2005
Newbie
I think the problem might lay in the fact that I have the tube about alot, but regardless here is some examples. Unmixed and mixed.
Unmixed Vocal
Mixed Vocal
please don't download that unless your going to help, I don't have alot of bandwidth on that server. thanks
Old 05-08-2005
scrubs's Avatar
Not of sound mind
Are you using a pop filter? That would be my first suggestion. You may even need two. The processing you've added is emphasizing the esses (sibilance). I would leave this voice pretty dry. Just a touch of room reverb and increase the predelay to 20-30ms or so. Also, experiment with different distances from the mic. Up close will give you more proximity effect (more bass and up-front quality), while further back will giver more ambience (less boomy and more room effect).
My tunage
Old 05-08-2005
Moonrider's Avatar
Moonrider Moonrider is offline
Dedicated Member
Moonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond reputeMoonrider has a reputation beyond repute
Ditto on the pop filter. Another thing you might try to reduce sibilance is singing slightly across the mic rather than straight into it.
Alice: How do you know I'm mad?
The Cat: You must be. Or you wouldn't have come here.
http://www.soundclick.com/jamesproject
Old 05-08-2005
Newbie
lol i'm using a pop filter. i guess that does need adressed. thanks for the advice.
Old 05-08-2005
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Something I did, and I am kind of loud, is turn the mic a little, so you are not pointing straight at the condensor. Put it slightly above or below your mouth.
I won the internets......
Old 05-09-2005
Newbie
i'll try that.
mics, mics, mics, ahhh!!!!! patlang12 Microphones 20 04-23-2005 12:34
More mics for sale. Angusdevil Free Ads for Music / Recording Equipment 7 03-23-2005 00:41
Budget mics.... what level of pres? cstockdale Microphones 26 09-19-2003 04:51
I'm looking for drum mics that won't let me down... Uladine Microphones 2 04-29-2002 06:26
How to use my darla to full potential... Fender Newbies 0 01-23-2000 18:48
