Old 05-06-2005
choctaw's Avatar
choctaw choctaw is offline
Tribal Member
choctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond reputechoctaw has a reputation beyond repute
Motu 828 Input Gain Question
When looking at a picture of the 828 the input gain panel has only 5 knobs for the 8 channels it can record on. Channel 1 & 2 have sperate gain knobs..but 3-4, 5-6, and 7-8 have one knob for each pair of inputs....just how does this work if you have different things pluges into the inputs 3-4,5-6,7-8, that you need individual gain settings. Seems weird, but I am probably missing somethings. I do not have one, just reading about how they work.
Old 05-06-2005
pdadda's Avatar
pdadda pdadda is offline
Captain Sea Boots
pdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond reputepdadda has a reputation beyond repute
I might have my terms confused, but I think gain refers to pre-amps. The 828 only has 2 pre's. As for the setting levels on the channels, you push one of the buttons and it selects between the different channels. Once you are on the desired channel, you turn the knob to tuen the level up and down.
Old 05-07-2005
earworm's Avatar
earworm earworm is offline
it might be true...
earworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond reputeearworm has a reputation beyond repute
i got the motu 828..
and its so cool that on the front there are volume controlls ,
too bad they are pairs,
lately i was recording a guitar on channel 7 and bass on 8
i had the volume button set at 50%, dead center to be certain the guitar wouldn't clip, guitar volume was nice, but bass was way too low
thank god the inputs of this motu are very clean and silent,
boosting the volume afterwards isn't a problem (depends on what you record trough of course...)
the easiest way to fix this problem: make sure you controll the output volume of your isntrument well...i did something wrong with the compressor that had the bass connected to it, thats why it was so silent
...listen...
Old 05-07-2005
Hard2Hear's Avatar
Hard2Hear Hard2Hear is offline
Retired from Audio
Hard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond repute
There are 2 mic inputs. All of the others are line level. You adjust them from the menu on the LCD. The knobs control cursors on the menu, not just individual channels.
H2H
Old 05-09-2005
mattamatta's Avatar
mattamatta mattamatta is offline
Force of Nature
Location: I told my friend that his anus was so big, that he had to get a restraining order for the local caving club.
mattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond repute
Yeah, those six knobs are setup, parater, alue, select, mix buss, and cursor, and they're all for adjusting settings regarding the unit's operation, and the mix of how the signal at the inputs is being sent back out various output pairs for monitoring purposes. No actual level control for the line level inputs - you'll do that on whatever you're feeding a line level signal into the 828 from.
The mic inputs, as you know, do have a gain knob, as well as a phantom power switch.
I'm pretty sure you can actually use both of those mic inputs in addition to all 8 of the analog line level inputs.;
blue motu 828 w/ pc vs ? zappacrappisshh Digital Recording & Computers 7 12-04-2003 14:04
motu 828 & pro tools lite??? stratman Digital Recording & Computers 1 08-07-2003 01:40
Preamp input gain problem? muser Microphones 3 02-01-2003 13:20
MOTU 828 Specs? mark4man Digital Recording & Computers 0 07-13-2002 09:47
Sync ADAT to Logic Audio 5 via MOTU 828 without BRC veiledsaber Alesis Forum 0 06-29-2002 20:58
