Thread Tools | Display Modes |
does anyone know where i can get used/new power supply for a bluetube for under $25!?
i just bought a bluetube used but it didn't come with a power supply. i called presonus and they said that a power supply cost $25, and that i can only use the one that they sell, no other one will work but both bluetubes use the same power supply though. if anyone knows anything that might help me then let me know, i'm on a tight budget. Thanks, Jason
You may wish to check www.PartsExpress.com
They have a large variety of wall warts to choose from. If you know the voltage output and current rating you need, you can check them. Also make sure the connector is right type. If doesn't match, you'll need change it. Know what your doing there though. Bob
May You Live All The Days Of Your Life |
Look at the back of the box. It will say how much voltage and amps it will need.
You can get wall warts from Radio Shack or any on-line electronics dealer. Just be sure to match the voltage and get at least as many amps as the box needs AND make sure the connector is the right polarity. Basic electronics, not rocket science... |
Manual for the BlueTube states 18 VAC @ 100ma.
The wart below may fit the bill. Probably have to change the plug to fit yours. As it's AC, the connector polarity won't make a difference. http://www.partsexpress.com/pe/showd...umber=120-1150 Buying the wart, a new plug, plus shipping you may be up close to what Presonus gets. |
thanks guys, i think i'm going to have to just buy one from presonus, if i'm going to spend the same amount i might as well have the official one. thanks again, Jason
| Carvin Power supply needed | Bitter Rain | Mixing / Mastering | 2 | 12-07-2004 20:50 |
| help! power supply producing a hum. | sproutrecording | The Rack | 4 | 11-24-2004 11:38 |
| Tascam 424 fluttering sounds - power supply? | RA Makaila | TASCAM User Forum | 4 | 04-29-2003 07:44 |
| Inadequate power supply? | Jagular | Digital Recording & Computers | 6 | 04-24-2003 08:59 |
