Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-04-2005
bad news bad news is offline
Junior Member
bad news is an unknown quantity at this point
Im Lost Now..MONO OR STEREO
mono or stereo when recording vocals..?
because the vocals seem fuller when its stereo..or is it no diff..
someone let me know
thanks
Old 05-04-2005
gtrman_66's Avatar
gtrman_66 gtrman_66 is offline
Dedicated Member
gtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond reputegtrman_66 has a reputation beyond repute
Vocal tracks are most commonly recorded mono. Backing vocal parts etc. can be panned across the stereo image, but each part is recorded as a mono track 99.999% of the time.
Old 05-04-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
mono = 1 mic
stereo = 2 mics
Your voice typically has sound coming from one place...your mouth. so you use one microphone. recording a track in stereo is usually meant for instruments that produce more than one sound (drums, acoustic guitars, choirs, piano, etc.)
---and you beat me to it gtr---
www.redlabaudio.com
Old 05-04-2005
XLR XLR is offline
______
XLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond repute
The only reasons I could see for using 2 mic's on a voice are:
1) you like the sound of your voice mic'd from a distance, have a great sounding room, so are mic'ing the room with a stereo pair
2) with close mic'ing, you like the combined sound of two different mic's positioned right next to each other (to avoid phase problems)
Tim
Old 05-04-2005
lotuscent lotuscent is offline
Senior Member
lotuscent is a jewel in the roughlotuscent is a jewel in the roughlotuscent is a jewel in the roughlotuscent is a jewel in the rough
depends on what you want to do with the mix. you can certainly do cool stuff with a stereo (or more) vox track...
there are limitless possibilities, really.
just because other people only see certain uses or applications for stereo vox does not mean you can't discover your own or talk to different people.
i'd say experiment if you have the time.
spiral!
http://mattyaki.com
Old 05-04-2005
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
The problem with stereo vocals is that it gets distracting at times.
You pretty much want the vocal track straight-up, dead center in the mix.
And what happens if you give the vocal any sort of stereo width ... is that if the singer doesn't stick his head in a vice or something, you get this very subtle, unfocused quality to it. Any time the vocalist "works the mic" in any fashion, you lose a little of that center focus as his head moves slightly to the left, to the right, or back. Basically, if the vocalist is in any way animated and likes to move around at all when he/she tracks, then you might run in to some issues.
Another issue is that you just have to be recording in a really good-sounding room, because it's going to play an even larger factor if you're stereo micing anything.
Old 05-06-2005
Junior Member
thanks to everyone in here
Old 05-08-2005
volltreffer's Avatar
volltreffer volltreffer is offline
Imply depressed
volltreffer is on a distinguished road
Cool
The only 'stereo like' thing I could think of is to use several mics on the same track to avoid clipping on louder parts. That MAY help in comping a good track in the end...
YMMV
aXel
Old 05-08-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
That still isn't stereo, it is just double mic'd. When you use 2 mics on a snare (top and bottom), it isn't stereo. It is just 2 mics on a snare.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Recording stereo or mono tracks -What's best? CTyankee Newbies 6 06-10-2003 14:36
Mono or Stereo - advice wanted darkwillow Recording Techniques 14 05-14-2003 13:11
More Stereo & Mono questions Alanfc Newbies 20 01-23-2003 18:03
Getting stereo synth parts into mono? Alchemist3k Mixing / Mastering 3 12-10-2002 10:06
Stereo vs. mono tracks? geekgurl Cool Edit Pro / Adobe Audition Forum 13 04-24-2002 16:45
