Old 05-04-2005
cheywind's Avatar
cheywind cheywind is offline
Junior Member
cheywind is on a distinguished road
Smile Mixer-MIDI-Audio Interface
Please explain what the difference between a Mixer a MIDI and an audio interface is?
What does each do?
Do you need all three?
Old 05-04-2005
Tifstorey's Avatar
Tifstorey Tifstorey is offline
Guinea Pig
Tifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond repute
a mixer controls the sound input/output. You can also change the EQ settings if possible. Picture: http://www.dv247.com/invt/547
MIDI interface is a unit that controls your midi devices. You plug the midi interface directly into your computer and then plug your midi controllers into the interface via MIDI cables.
Picture: http://www.dv247.com/invt/9264
Audio Inteface is basically your soundcard. These can come in either PCI, USB or Firewire, depending on your choice.
You dont need all 3 if you want to start recording. If you want to record audio tracks, i would say get a souncard. A midi interface is essential if your soundcard doesnt have MIDI connections on.
Hope that helps a little.
Old 05-04-2005
Tifstorey's Avatar
Guinea Pig
Oh, and ive just noticed youve posted 4 times with essentially the same question... Please dont do this it will upset people...
Old 05-04-2005
Monkey Allen's Avatar
Monkey Allen Monkey Allen is offline
creeping moses
Monkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond reputeMonkey Allen has a reputation beyond repute
A midi is typically a connection type for keyboards
A mixer is a device that enables you to manipulate multiple imputs/ outputs....eg. the volume, panning, maybe even effects like reverb
An audio interface is the type of audio hardware that you use. Some audio interfaces could be PCI, usb or firewire. Or the audio interface could be the software that you use to control the hardware....like sonar or cubase.
People less noob than me will help you to. We can't have noobs helping noobs here. I am just practicing my knowledge. People will correct me if I am wrong.
Good luck
Old 05-05-2005
cheywind's Avatar
Junior Member
Thank you....brand new...gettting use to things
Old 05-05-2005
cheywind's Avatar
Junior Member
Good luck
Could you explain the difference between 'mixing' and 'mastering'?
Old 05-07-2005
cheywind's Avatar
Junior Member
My Edirol unit is then the (MIDI) interface you are talking about?
Old 05-07-2005
Tifstorey's Avatar
Guinea Pig
Your edirol will probably be a audio and midi interface, i cant be certain but i would think so.. What model is it?
Old 05-09-2005
cheywind's Avatar
Junior Member
Question
Edirol UA25 USB Stereo Audio Interface EDIUA25 - that what you mean?
Old 05-09-2005
Westridge Westridge is offline
Newbie
Westridge is on a distinguished road
Yes, that's correct.
Your Edirol is an audio/midi interface. It is a combination of an audio and a midi interface, and in your case, it uses a USB cable to connect to your computer. Some audio/midi interfaces use a Firewire cable, some look like a computer circuit board and are plugged directly into the back of the computer, others look like your Edirol.
Oriion, Rebirth & Fruityloops with Sonar acgt Cakewalk / Sonar Forum 10 09-13-2002 13:21
CD Writing Stephen Jones Cakewalk / Sonar Forum 15 10-12-2001 16:42
Converting MIDI to WAV AndrewSales Cakewalk / Sonar Forum 38 08-21-2001 22:31
MIDI to Audio using a keyboard's sounds - question HomeRec Digital Recording & Computers 7 07-17-2001 19:07
new studio need help.. fast!! Readytodothis Newbies 8 04-06-2000 01:55
