Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 05-03-2005
The Engineer's Avatar
The Engineer The Engineer is offline
Senior Member
The Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond reputeThe Engineer has a reputation beyond repute
Vocals Sounding Muddy, Help
I do a eq cut off on my preamp from 60, then it sounds tiny. When I record normally my vocals tend to sound muddy and real close up, even though I'm not spitting that close to the mic, maybe 6 inches or so.
Equipment:
AT4040
E-mu 1212m soundcard
Roland MMP-2 preamp
Closet 4X5X8 covered with 2" acoustic foam
Any help on this, I'd really appreciate it.
Old 05-03-2005
Dogman's Avatar
Dogman Dogman is offline
Campeón de la Internet
Dogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond reputeDogman has a reputation beyond repute
Engineer, I have the same mic, and have had a bit better luck turning the pre up, and moving back maybe 12-18". But I am loud. I also use a RNC compressor, to tame some of my loudness. I still have to eq a bit on the pc when done recording, and it by no means is great, but at least now my voice isn't really thin.
Hope this helps a bit.
Ed
I won the internets......
Old 05-03-2005
Senior Member
Well If I stand back it sounds weird, because my booth isn't acoustically treated, when I stand back my vocals sound "boxy." So I have to stay pretty close for it to sound good, just don't know where the muddiness is coming from.
Old 05-03-2005
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Very likely due to the fact that you're singing in a box, basically. Honestly, looking at a typical vocal booth ... isn't it just basically a big, rectangular box-like object? Is it really surprizing that things sound "boxy" inside that box?
Old 05-04-2005
Senior Member
True, well actually it was my friends voice who's was sounding muddy, I recorded some stuff yesterday and it sounded fine, although is there anything to fix that boxy sound? I know studios that have the same size booth as mine, but theirs was professionally made, and they're don't sound boxy, I don't know what to do about it, but any help is appreciated.
Old 05-04-2005
chessrock's Avatar
Banned
Stand closer to the mic.
Old 05-04-2005
FALKEN's Avatar
FALKEN FALKEN is offline
FALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond reputeFALKEN has a reputation beyond repute
cutting up to 60 should have almost zero audible effect. you should be able to cut up to 250. maybe cut 12 db. I always use low cut on vocals.
Old 05-04-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
250
don't think i've ever gone that far
audio?
seriously, give me negative rep.
Old 05-04-2005
AlexW AlexW is offline
Force of Nature
AlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to behold
If it makes it sound better, do it.
Old 05-04-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Try recording in an average room in a house with a carpet and no tiling etc.
Sing up very close to the mic, almost eating it! and compress it on the way in to ensure a good level. Try attack of 5ms and release of 50ms,with ratio of about 2.5:1 and play bout with the threshold to get a decent level.
Or you could use a limiter or hard compressor. Watch when using the later two though as your vocals might end up sounding unnaturally dynamically changed, and there isnt anything you can do about that once its recorded like that.
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 05-04-2005
Senior Member
When I use a lo-cut on my preamp my vocals sound robotic and very thin/tiny. I just use a lo-cut on my mic, that's it.
ecktronic my open room has a more natural sound, kind of a big reverb though, but actually not that bad. lol
Thanks everybody
  #12
Old 05-04-2005
Clit Torres's Avatar
Clit Torres Clit Torres is offline
Dedicated Member
Clit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these partsClit Torres is infamous around these parts
Hey Engineer, check your pm's.
  #13
Old 05-06-2005
ecktronic's Avatar
The engineer, this type of room could be contirbuting towards your muddiness if it isnt the mic or the pre amp. I have always found that getting any room reverb in a vocal recording makes it sound muddy. I tried a really nice Neumann mic for vocals once, but it was too sensitive and picked up all ambience in the room, so i used an NT2 and got 100 times the results! Sometimes price isnt everything in getting a good recording.
CRYSTAL MIXING
MY BAND
  #14
Old 05-06-2005
Senior Member
Well the open room has a reverb, not my booth. It was the guys voice I suppose, cause only his voice sounds muddy on my mic.
Thanks for help everybody.
Torres I'll check my pm's too.
where do you sit your vocals? jugalo180 DJ & Hip Hop Production 5 03-31-2006 12:31
Anyone want to mix? kdoggity Digital Recording & Computers 86 03-24-2004 20:04
More Odesa! Recorded some vocals, jam on this... tubedude MP3 Mixing Clinic 11 04-20-2003 04:49
Help ! Muddy Vocals When Recording walkindaddy Microphones 5 07-29-2001 21:35
Remove vocals question Mike Richardson Digital Recording & Computers 4 05-23-2001 10:05
