Tube Mics?
I have a couple of LD condensers, and a couple of SD's --- Alwyays here so much about the quality or differnent uses of a Tube condenser.
Question: How to they hook up? Does the mic hook into the box then the box to your pre? Sill need phantom power? If my ship comes in would like to try one? (currently my ship is leaking and listing badly to the port side) |
You are right.
They typically plug into a power supply that comes with the mic whichprovoides the power for the tube,and also provides phantom power. You generally have a balanced out that you run to a preamp. (You still need one of those!:0) Tom
Tom Menikos T-Mix Studios Mansfield Texas WWW.tmixstudio.com |
Thanks Tmix-- that's what I thought, but like it says you can ask anything in the Newbie forum!
Gotta get a good answer coming outta Mansfield TX!!! |
You bet!
Thats what it is all about in THIS forum! Step out of this one and WATCH OUT! Tom
The newbie forum is where I can hide from Chessrock!
Ssshhhhhh! He might hear you!
I think he is coming! Outta here! Tom
The power supply for a tube mic is split into two dedicated clean power sources. One is for the tube's heater filament, the other is for the tube's plate voltage. The heater is typically around 6.3 volts, whereas the plate voltage is anywhere from 100-200 volts, although neither of these are absolute rules, as it depends on the type of tube used as the amplifier. From there it has a small amount of the plate voltage leaked to the diaphram and cathode bias through resistors. Phantom runs equal to or lower than 48 volts, which is really not enough to power the plate of a tube. Tube mics ignore the phantom power and are considered to be "passive" to phantom power.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life." |
Phil,
I stand corrected. I guess what I really was trying to imply in my uneducated way was simply that the power supply for the mic supplies all the power needs for the mic. I was throwing terms around I shouldn't have. Thanks for your explanation. Tom
Oh, I'm not jumping on you! I was just trying to clarify the concept for anyone reading. Don't worry about any errors. I make 'em too, and they're quickly corrected. That's the great thing about this place, you get good info quickly.
Hell, someone higher up will probably correct something I wrote here.
like chessrock.....................hes so dreamy
when the dust all settles and all of us have gone our life ways, the only thing anybody will care about in those recordings is the content. The songs and how they are performed. - SouthSIDE Glen |
even more stupid...
I think I have the most basic question about tube mikes ever (or rather, a set of questions). In the following paragraphs, I'll write some things like they were facts. If something is wrong, please chime in! I only want to avoid writing "as far as I know" etc. in front of every statement.
A tube mic is a type of condenser microphone which uses a tube in the amplifier path. Condenser mike: this is basically two plates which are charged relative to each other. This leads to a certain voltage between the plates. If you vary the distance of the two plates (which happens when sound hits one of the plates - the diaphragm), by basic physical laws, the potential (voltage) between the plates changes. We can use this potential change and bring it to a mixer and thus have our signal. Problem #1 - get the charge on the plates in the first place. Solution: Phantom power, a battery, plates which have the charges on all the time (elektret) or Tonaderspeisung. Problem #2 - The voltage source (i.e. the condenser) is a high-ohmic voltage source which you can't connect to your mixer directly. So you need to transform impedance. This can be done by a transformer or by a NIC, which you build using either a FET or a tube. If you use a tube, you still have the impedance problem. So you still need a transformer or a FET after the tube. The tube has a ridiclously high input impedance compared even to the best MOSFETs - which is good in our case. Also, it gives us the "tube sound" (which is good or bad, depending on the recording situation). The tube itself (which works as an amplifier) and the relevant electronics are housed in the microphone body. The external box is only there to supply the charge to the plates of the mic, the bias voltage to the tube and the heating current to the tube. Every tube microphone contains either a transformer or a FET after the tube stage. Every (serious) condenser microphone contains either a transformer or a FET after the diaphragm. The use of phantom power for elektret microphones is to power the amplifier in the microphone. Ok, now tell me where I'm wrong. Rainer |
#12
#13
I left a link on the mic forum for the real experts to point this thread in the right direction. You'll get more accurate info from them.
Phil
#14
Dear Phil,
thanks for your reply. To comment on a few of your comments (e.g. explaining what "Tonaderspeisung" is) see below. You told me (in your next message in this forum) that you left a link in the microphone forum - which unfortunately I was not able to find. Could you point me in the right direction there? Thanks, Rainer Quote:
"Tonaderspeisung", also known as T-Speisung or T-Power, is a predecessor of phantom power but works more or less the same. You'll find it on really old microphones. Quote:
#15
I have no doubt that if an FET amp can work with a tube (or without) and either use a trnasformer or not, that it can be designed to use a tube with an FET and no transformer. As far as I know there are no absolutes. Like I said, the guys in the mic forum know a hell of a lot more. The link I left was for them to double check my info, but it doesn't appear to have struck an interest. If I were you I would read what they call "Harvey's big thread" - (Its actually "how does diaphram size/polar pattern relate to...". First thread on the mic forum.), then post any questions you have regarding this. I'm sure you probably know more than I do, but SOME of the guys here just blow me away. Always learning... BTW, a "voltage follower" (source follower, cathode follower) can also be done using a tube. The impedance is lowered, but may still need a transformer. Not all FET circuits do the voltage follower either.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life." Last edited by PhilGood; 05-11-2005 at 01:19.. |
| Some things to think about when choosing mics. | Harvey Gerst | Microphones | 53 | 1 Week Ago 11:08 |
| Tube mics, what do you think? | zoj99 | Microphones | 1 | 10-18-2003 06:26 |
| Ancient mics and other tales | Middleman | Microphones | 1 | 02-10-2003 16:47 |
| AT4060 vs vintage tube mics | lilcapn | Microphones | 0 | 09-28-2002 00:39 |
| Tube mics with a lot of patterns | c9-2001 | Microphones | 9 | 06-19-2002 10:46 |
