tascam 38 head cover!
Eagerly awaiting delivery of a tascam 38 and seller tells me that the head cover (with the name 'tascam 38' on it) keeps springing off!! Is this fixable, do I need a new part? I think the guy I bought it from has just fitted a new pinch roller, taken the machine apart and maybe can't get the head cover back on properly.
ANY help would be GREATLY appreciated!! |
There's not much in the way of fixing that can be done, if it's damaged.
a.k.a. Davemania! Beatles and other Classic Rock covers!! Yeah, Yeah, Yeah!!! 637 songs by 191 bands.
I don't see how it can keep springing off if it's screwed on properly, it's just two screws and really easy to attach.
I have another question (forgive me for hijacking) On my Tascam 38, the Right reel table hub seem to have loosened up and went in like 2mm into the machine so the reel scratches against the machine and it wont run. Now, I can pull it out again and the machine will run for a few minutes, then it pops in again and the machine stops. Anyone have experience with this? |
Either way works for me! Enjoy. |
Maby I'll see/reach it from behind? It's not the table but the hub itself that's loose I think. |
You wil have to take the face off of your machine to fix this. there are two phillips screws under the reel table that need to be tightened.
Just take your time and make sure the table is at the correct level before you put the face back on. When taking the front panel off there is a bushing that screws down under the pitch control knob that is easy to miss that has to come off before the front cover will come off. I think I used a long pair of needle nose pliers to get to mine. Or maybe if its not to tight a screwdriver will work. Also be careful when lifting the top face off cause the wires are pretty short on the control buttons. If you place the face plate just right you wont have to disconnect it to work on the machine. Also be careful with the little metal flap that protects the heads in the center it can get in the way while taking it aprart and putting it back together. Its not hard these are just things I had to learn while doing mine that can save you some time. Good luck with your machine. |
Thanks for the help, I'll get down to the studio tomorrow and try this.
Also sorry again "tapeboy" for hijacking your thread. |
Okay, back to the head cover.
It's a 2-piece unit. The part that attaches to the faceplate is set by two screws, but the part with the name on it is a hinged piece of plastic, that hinges off the other piece. It's only a little plastic clip, with a metal clip backing for spring tension. If it's damaged or missing, (in this clip area) you have to replace the whole enchilada. Okay?
Where do I find a 1" 8 track??!!
thanks for the tascam 38 'name plate' help, it helped. Any one know where I can find a nice 1" 8 track? Just missed a Brenell mini-8 for 200 pounds!
| Why I won't buy the Tascam 2488 | A Reel Person | TASCAM User Forum | 312 | 07-05-2005 11:33 |
| Tascam 1/4'' tape reel to reel | DESSERT DWELLER | Analog Only | 2 | 02-01-2005 01:09 |
| Urgent: Tascam MS-16 / MSR-16 / ATR-60 ? | gilwe | Analog Only | 24 | 01-30-2004 08:33 |
| Tascam 414MKII AC adapter (PS-414) | Noplasticrobots | TASCAM User Forum | 5 | 11-18-2003 20:57 |
| cakewalk home studio 2004 and tascam us 428 problems | lonman | Cakewalk / Sonar Forum | 5 | 11-02-2003 06:06 |
