Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 04-30-2005
coolsoundman coolsoundman is offline
Senior Member
coolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond reputecoolsoundman has a reputation beyond repute
Master volume levels?
hey folks,
when you guys are mixing and your ready to do the mixdown of your tracks, where is your volume set at on the main mix channels? When I do a mixdown on my tracks, my master volume is set at 0 (zero). And at that volume, my song sounds a little on the soft side, but the meter doesnt go into the red, its all in the green zone. So I ask, where do you have your master volume slider set at and will it do any bad, as to get into the red zone, on the main mix slider?
Old 04-30-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
No simple answer there, as it would be completely dependent on the levels of the individual tracks going to the master buss.
Try to keep your mix level peaking at around -6dBfs (NO clips!!!) and call it a day.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 05-01-2005
masteringhouse's Avatar
masteringhouse masteringhouse is offline
www.masteringhouse.com
masteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond reputemasteringhouse has a reputation beyond repute
Originally Posted by coolsoundman
hey folks,
Is this an analog or digital console?
Tom Volpicelli
The Mastering House Inc.
MySpace:
www.myspace.com/masteringhouse
Old 05-01-2005
Senior Member
I have a yamaha 16g recorder, and i guess that is digital, my mixer board is anolog and I'm using Sonar for my editing and mixing. I hope that helps.
Old 05-02-2005
You want to try to keep settings at their "nominal" levels. For an analog console you will get a better signal to noise ratio if you keep the master fader at zero and bring up the track volumes so that you are reading 0 on the VU meter (analog VU meter).
For digital the noise ratio is less important and you can bring the master fader up, however it's still best to try to keep it at zero in order to avoid additional processing to the audio. At 0 it "should" remain untouched after summing. Again, you will need to raise the track volumes so that the overall volume is appropriate for the song.
With both, if recording to digital, try to keep the peaks way from 0 dBFS. The -6dbFS cushion that John speaks about is a good standard for 24 bit audio. If the average (RMS) level isn't as loud as it should be that's generally OK. For most material it should read somewhere around -18dBFS (this corresponds to 0 on most VU meters) with peaks obviously below 0 or around -6 dBFS. If the average level is much lower than -18dBFS, you will probably need to compress the tracks that are causing the peak volumes (usually kick and snare drums) a bit in order to get the average volume up. But again, if it's somewhere in the "nominal" range don't sweat it too much, that's for the mastering stage.
Tom Volpicelli
MySpace:
Matching volume levels...and some other glitches RobTob Recording Techniques 6 11-11-2004 11:13
Mic Volume Levels? jb2004 Microphones 6 08-14-2004 16:17
volume levels problem Laynestaley Cubase User Forum 2 02-19-2004 15:59
What is going on with my levels? coplinger Sony Tools / Sonic Foundry 5 09-20-2002 06:04
raising or "normalizing" volume levels?? bloozguy Cakewalk / Sonar Forum 10 08-04-2002 08:13
