Help 1010lt And Mg16-4 Mixer
WHEN RECORDING VOCALS I DO NOT GET ENOUGH OUT OF THE HEADPHONES
ALL I HEAR IS MUSIC AND VERY LITTLE VOCALS AS I AM TRAcking.....i am RUNNING THE 1-2 OUT ON THE SOUND CARD AS THE MONITOR MIXER OUT INTO THE 2TR IN ON THE MIXER THROUGH THE PHONES WHILE RECORDING.....I AJUST THE SOFTWARE BUT CANT GET ENOUGH VOCALS IN RELATION TO THE MUSIC???? I KNOW I SHOULD PROBABLY DO THIS ANOTHER WAY BUT WHATS THE BEST METHOD???
PRO |
First STOP SHOUTING. Posting in all caps is considered SHOUTING and it's hard to read and is considered bad form.
If you have extra channel inputs on your board bring the output of the computer back thru there. Then you will be able to balance the levels more accurately and hopefully can increase the level of the headphones so everything you need to hear will be audible. |
If you select Monitor Mixer in the Patchbay/router tab of the Delta Control Panel, then you can adjust the levels of master volume and wav outs 1 & 2 to get a balance between what you're recording and what's been recorded.
Adjust the CR-Out knob on the mixer to get more volume. Make sure the 2 TR-In know is on zero so you don't get bleed onto the track you're recording on |
Ive Tried Ajusting The Main / Out 1-2 On The Mixer Tab ...but Am Still Not Getting Enough Volume On The Vocal Track...
PRO |
