Go Back   Home Recording > User Forums by Brand > Alesis Forum
Reply    Audiofanzine Alesis Alesis News Alesis Medias Alesis Tests Alesis Articles Alesis User Reviews Alesis Classifieds Ads
Old 04-26-2005
crgl crgl is offline
Junior Member
crgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant futurecrgl has a brilliant future
Alesis D4 noise....
Hi:
I have an Alesis D4 Drum Module. When I bought it a year ago the only thing that didn't function was the display, but I could handle that.
It sounded perfect and responded perfectly to my playing.
Then suddenly it began to act strangely.
When I first turn it on it functions perfectly, but then the sound begins to crackle in some pads and slowly it becomes unplayable.
Does anyone has experienced this with Alesis D4 or other Alesis gear ?
Maybe the problem is easy to correct since when I turn it it works perfectly is just that slowly it becomes bad.
Old 04-29-2005
Junior Member
I discovered that it had to do with heat building up in some component on the D4 because when I brought it to my workplace, where air conditioners keep offices very cold, the D4 sounded perfectly at least for a considerably longer time.
SOMETHING STRANGE:
When I brought it home it sounded bad , because of the heat outside I suppose.
Then, I did the following, put it in a box and got it into the freezer for 5 minutes.
RESULT: It sounded perfectly for all the time that I kept it turned on ( 4 hours ).
What do you think is the cause of malfunction ?
Old 04-29-2005
firby firby is offline
Senior Member
firby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond reputefirby has a reputation beyond repute
I dont know what is broken with it but I do know that D4s are super cheap at this point.
I Need Help With Editing. Key Rogue Cool Edit Pro / Adobe Audition Forum 14 11-30-2005 00:37
FS: Alesis MultiMix 16USB Mixer with USB Audio zeav Free Ads for Music / Recording Equipment 0 03-12-2005 12:18
Noise from not being grounded? Rane MS1b W.S. Walcott The Rack 0 08-23-2004 17:23
electrical noise killing my recording! doughulin Fostex Forum 4 08-15-2004 16:50
Dithering darnold Mixing / Mastering 27 12-13-2001 21:29
