Go Back   Home Recording > Equipment Forums > Guitars and Basses
Reply    Audiofanzine Guitar Guitar News Guitar Medias Guitar Tests Guitar Articles Guitar User Reviews Guitar Classifieds Ads
Old 04-17-2005
Mr. C Mr. C is offline
Senior Member
Mr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond reputeMr. C has a reputation beyond repute
Question Ratings on pickups????
I'm looking at a few pickups, SD, and some PAF from Customparts.com.
The PAF are rated at 8.48 for the bridge, and 7.85 for the neck. On the SD site I was looking at the JB and it has ratings for the D.C. resistance, and the resonant peak. So what do these categories mean (I imagine it has something to do with the output). So are the PAF ratings the D.C. or resonant peak??? HELP!!! and... thanks!!!
Old 04-17-2005
Hard2Hear's Avatar
Hard2Hear Hard2Hear is offline
Retired from Audio
Hard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond reputeHard2Hear has a reputation beyond repute
Those ratings (in ohms) are dc resistance. But the only real way those numbers really mean anything is when you are comparing pickups that are exactly the same to each other. Same magnets, same wire, same construction. Any of those variables change and the numbers go out the window as a way to compare pickups to each other.
H2H
Old 04-17-2005
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Yep, just put 'em in and play. Then you will know which one sounds right for you.... if that's an option...
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 04-17-2005
goldtopchas's Avatar
goldtopchas goldtopchas is offline
Dedicated Member
goldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond reputegoldtopchas has a reputation beyond repute
The resistance of the pick-ups relates to the output, but as mentioned it kind of doesn't matter in the grand scheme of things. The actual tone is probably more important to most musicians. The ones I use are pretty high output. 13.5k for the bridge and 12k for the neck. I use a 76' jmp master vol. Marshall and I like to "push" the input of the amp for distortion.
If you use a pedal for distortion, or a solid state, or even a modeling amp, chances are that you'll wind up with a better tone using pick-ups with less output. I've found that high output pick-ups usually have more mids and highs than weaker ones. More of a "cut through" tone. Vintage models like "PAF's" are more warm and smooth sounding in my opinion. Of course, it all depends on the sound that you're going for and the amp & effects you use.
The resonant peak has to do with the frequencies that are most pronounced in the pick-ups response. Kind of like a speaker cab. response.
I think I saw a good bar graph on Di'marzio's site that showed bass, mids, and treble of each of their models as well as output. It was a good visual aid as far as understanding what the performance of each pick-up would be like.
"Is this thing on"??????
Bill Lawrence pickups and controversy charger Guitars and Basses 17 09-07-2006 19:30
Fender "Noisless" pickups? Are they shit or not? pisces7378 Guitars and Basses 15 06-06-2006 07:02
Can you help identify these pickups? Easto Guitars and Basses 3 01-30-2005 08:15
Fender "Noisless" pickups? Are they shit or not? (the shorter version) pisces7378 Guitars and Basses 5 08-11-2004 12:36
Know of a good soundhole pickup for acoustic guitar? jeffree Other Equipment and Reviews 11 05-07-2003 18:29
