Old 04-06-2005
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
DI for bass with 2 outputs
I am looking to get a DI, primarily for recording bass guitar and I would like to be able to capture a direct signal as well as mic the bass cab. So I need a DI that has one 1/4" input and then a 1/4" output (to go to the amp) as well as a XLR (to go to the board). Is there a DI that is set up like that? Or is there another way to get it done with a regular DI?
Thanks
Amra
Old 04-06-2005
scottboyher's Avatar
scottboyher scottboyher is offline
The King Of Nothing
scottboyher will become famous soon enoughscottboyher will become famous soon enough
YOu could go from the bass to the amp then use the line out to the DI box. Then just mic the cab.
_______________________________
www.scottboyher.com
info@scottboyher.com
Old 04-06-2005
sile2001's Avatar
sile2001 sile2001 is offline
_|_
sile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond reputesile2001 has a reputation beyond repute
If you don't have a specific amp you were wanting to use, the SansAmp Bass DI's are excellent for this purpose. It has a 1/4" input from the bass and a parallel (uneffected) 1/4" output. It then runs through its processing circuitry, and then gives you the option of mic level or line level over XLR, or line level over 1/4". Pretty good stuff...
Old 04-06-2005
sweetnubs's Avatar
sweetnubs sweetnubs is offline
Force of Nature
sweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond reputesweetnubs has a reputation beyond repute
Lots of Di's function this way. 1/4" input with a 1/4" output which you send to the amp. Usually an XLR output for the DI singnal. Try to use as short as cables as is possible for your 1/4" (unbalanced) connections. (guitar to DI and Di to amp) The XLR is for your long run to the preamp. Less noise since it is a balanced connection. I recomend the Countryman DI on the cheap. (around $150) See my nubs are sweet! Hope this post complies with 8th grade reading level requirements!
Old 04-06-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
another vote for sans-amp (tech 21) you can also use it as an eq or distortion pedal. that company makes good stuff.
i've used it to warm up direct keyboard sounds too
(like adding a small amount of distortion to an organ sound to try and fake a leslie sound, no one gets fooled but it dose sound better)
Old 04-06-2005
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
As far as I know, all DI's offer that function. Personally, I will never buy anouther Countryman DI again. We have 12 of them and every single one is constantly needing minor repairs. They do sound good though. On the other hand, I find that both the radial and the BSS DI's are about the same price, and sound just as good if not better. Not only that, but are MUCH more durable. The BSS DI's also have an easy access battery compartment, a power switch, a 2 position pad, both male xlr and female xlr jacks, and nice rubber feet which make them very stackable and durable.
Old 04-06-2005
amra's Avatar
1K Silver Member
I had planned on getting a Tech21 Bass DI, but then I started hearing about sadowky and countryman DI's and using just plain mic preamps for DI. When I do get one, I want to be able to go direct and mic the amp.
Thanks for the advice, all. I wasn't sure if most direct boxes had the features I needed or not.
Amra
Old 04-06-2005
sweetnubs's Avatar
Force of Nature
You could use a mic pre but then you got to lug it around and you may or may not have an output to an amp. If your pre is racked then you defeat one of the purposes of using a D, to convert the unbalanced signal to balanced so you can run it long distances. Countrymans are fine and somewhat of an industry standard. I don't own any anymore but still use them on occasion. They are a good cheap DI. Never had too many issues with them in the past. Hmmmm.
Lost outputs in CubaseLE/Firepod/XP kuthu Cubase User Forum 3 03-23-2005 13:20
tape output=main outputs? drumboi Digital Recording & Computers 4 07-22-2004 12:36
midi outputs and fx for music creator 2003 drumboi Cakewalk / Sonar Forum 0 01-27-2004 23:59
How to mute mixer outputs? deafen The Rack 6 01-12-2003 15:31
QSR FX Outputs Terry Alesis Forum 0 07-05-2001 05:50
