Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 04-06-2005
borntoplease's Avatar
borntoplease borntoplease is offline
Senior Member
borntoplease is on a distinguished road
Frustration Recording My Vocals
okay... so im having trouble recording my vocal tracks. im good when i sing more quiet nuanced stuff... i crank the pre and get up close on my mic (ADK Vienna) and through on some compression and i get a nice "up close" vox track that really has some presence. but, when i go louder, i cant get it right. im not screaming or yelling, just REALLY singing, putting some stomach into it. and i cant get a good sound. i dont know how far away i should be from my mic, should i roll off.. the ADK has an 18dB pad on it. it just seems that i have to keep the level so low as not to peak that i loose a lot of the presence. it sounds like im just singing loud in a room.
so, should used the pad? should i keep the pre low and get up close on the mic? or back off the mic and keep the pre hot? i've tried everything and i cant get the presence i want out of the louder parts... what should i do???
Mac G5
Dual 1.8GHz
Digi 002R
PTLE 6.7
Old 04-06-2005
PhilGood's Avatar
PhilGood PhilGood is offline
Juice Box Hero
PhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond reputePhilGood has a reputation beyond repute
It's very common to track loud and soft parts seperately. The usual problem is on loud parts, you can saturate the transformer or tube if it's a tube mic. The pad reduces the voltage from the capsule to the head amp in the mic and keeps it from clipping. That in turn keeps your preamp from being hit too hard.
“Build a man a fire and he'll be warm for a day. Set him on fire and he'll be warm for the rest of his life."
Old 04-06-2005
Senior Member
Originally Posted by PhilGood
It's very common to track loud and soft parts seperately. The usual problem is on loud parts, you can saturate the transformer or tube if it's a tube mic. The pad reduces the voltage of the head amp in the mic and keeps it from clipping. That in turn keeps your preamp from being hit too hard.
i do track them seperately. how hard is it to actually distort an LDC? do you recomend closer with more pre, or further back with less pre? i just want presence out of my vox...
Mac G5
Dual 1.8GHz
Digi 002R
PTLE 6.7
Old 04-06-2005
PhilGood's Avatar
Juice Box Hero
It's very easy to distort it. My wife can drive mine to fuzz. The best thing is to turn the pad on for the loud parts. A -15dB pad makes the mic capable of 150dB. That's WAY louder than any human voice can hit. Use the pad and up the pre to the level you need at the loudest part. You can be about 8-10 inches away, but play with it. Compression on tracking helps too.
Old 04-06-2005
artCROSS artCROSS is offline
Senior Member
artCROSS is on a distinguished road
This may not work for you, but here's what works great for me.
I always sing right up against the pop filter, so my nose it literally touching it, as loud as I usually sing. I also compress on the way in; not too much, but just enough to prevent clipping. Then I turn my pre up til it's in the yellow. I get a nice track every time.
Old 04-06-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
You may be distorting the pre, compressor, or converters. Turn down the pre. Get up close (4-6") for intimate parts, and back off (12-18" or more) for louder parts. It takes practice and experimentation.
There is a formula for how much the level drops for each inch further you get from the mic, but I can't remember it off the top of my head. Perhaps that, in conjunction with an SPL meter would get you in the ballpark.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 04-07-2005
tradivoro tradivoro is offline
Newbie
tradivoro is on a distinguished road
This works very well.. I tried it with a mic that I similarly was not getting good results when singing loud parts and now, the mic sounds great.. Thanks for the tip...
Old 04-07-2005
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
Sounds like a problem with the acoustics of your room. Quick fix may be to hanging some thick comforters/blankets on a boom mic stand directly behind your mic, make a U shape around the back of the mic if you have an extra stand.
I wish my lawn was Emo so it'd cut itself.
Old 04-07-2005
Brent Casey Brent Casey is offline
Just add water and stir!
Brent Casey has a spectacular aura aboutBrent Casey has a spectacular aura about
If you are using a mic that begins to show nonlinearities between 90-100dB and has 22% THD at 130dB from a 1kHz tone, then the answer to your question is: it's very easy to distort.
Brent Casey
Old 04-07-2005
mshilarious's Avatar
mshilarious mshilarious is offline
Faithful Departed
mshilarious has disabled reputation
Yep, acoustics problem. Ever see the clips of pros recording in studios? When they are belting out loud parts, they are a foot or more from the mic. That's sort of the point with condensers; they are sensitive enough that you don't have to eat the mic.
But as you discover, as you move farther from a mic, then the room volume is proportionally louder to the source volume at the mic. This is why pros record in good sounding rooms, and homereccers build vocal booths . . .
You might find a dynamic mic more to your liking.
Recording gang vocals? complexprocess Recording Techniques 17 07-25-2008 07:17
Recording vocals please help fast jiffy999 Microphones 20 03-28-2005 20:46
recording guitar and vocals at the same time guitar junkie Recording Techniques 7 11-07-2004 07:57
Recording Vocals SirPsychoSexy Recording Techniques 9 02-06-2003 15:10
Recording vocals 4Music Recording Techniques 2 01-21-2003 02:43
