Old 04-05-2005
curtiswyant curtiswyant is offline
Junior Member
curtiswyant is on a distinguished road
Should I be recording in 24/96?
I've got a Delta 1010 and I've never bothered to change the settings from 16/44. Just wondering if, since I can, should I be using the card to its full potential at 24/96?
Old 04-05-2005
MadAudio's Avatar
MadAudio MadAudio is offline
Damned if I do
MadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond reputeMadAudio has a reputation beyond repute
You should at least up the bit depth to 24. With 24-bit, you don't need to record as hot as 16 bit, and IMO it sounds better. I also think 96k is overkill for most home recording, and besides it eats up drive space.
Newest endeavor: Playing drums in a live band version of 7 Door Sedan's music.
"Do yourself a favour just shut up, read up then put up." --muttley600
Old 04-05-2005
reshp1's Avatar
reshp1 reshp1 is offline
1K Silver Member
reshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond reputereshp1 has a reputation beyond repute
What he said, 24bit gets you 256 times the resolution for 50% increase in HD space, CPU load. That means you don't have to really worry about getting a "hot,"near 0dB signal into the DAW, it'll sound just as good in 24 bit if you signal is say -6 dB.
the 96k debate has been done to death, but most people agree that they can't hear the difference, although if you do up sample rate, it's better to go to 88.2k, since the math is simpler once you inevitably have to come back down to 16/44.1 to put on CD.
I wish my lawn was Emo so it'd cut itself.
Old 04-05-2005
TimOBrien TimOBrien is offline
2.5K Gold Member
TimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond reputeTimOBrien has a reputation beyond repute
Definitely 24bit.
96k will severely reduce the number of tracks you can run and the number of plugins you can run. And eat up hard drive space.
And you still have to go down to 16/44.1 for CDs....
Old 04-05-2005
XLR XLR is offline
______
XLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond reputeXLR has a reputation beyond repute
I can hear a big difference between 16 and 24 bits. But not so with the sample rate difference.
Tim
It's easy to pose as an audio expert.
Do a background check... listen to their work.
Old 04-05-2005
boomtap's Avatar
boomtap boomtap is offline
Dedicated Member
boomtap will become famous soon enough
I have always beleived that unless you have all of the other equipment to back it up (high end mics, clean power, and great room) then recording at 24/96 isn't really going to gain you anything. Even some of the Class A studios I go into with millions in gear feel that 24/96 isn't that special escpecially with the way mastering to high levels has ruined the overall fidelity of recordings. They always opt to eliminate all conversions. If you are going to a 16 bit final product then record in 16 bit. That is at least what I have bought into. Besides everthing gets mp3ed now adays, the only one who will apriciate the full size awsome unmastered recording will be you.
Old 04-05-2005
XLR XLR is offline
______
You're making a good point. With lower quality gear and rooms money is possibly better spent to improve the front end or the recording space. Also I think it's important to recognize that sound quality of converters is determined to a large extent by other things than wordlength and sample rate.
Tim
Old 04-05-2005
Janesaid2me Janesaid2me is offline
Senior Member
Janesaid2me is a jewel in the roughJanesaid2me is a jewel in the roughJanesaid2me is a jewel in the rough
Def 24 bit its huge diff between 16....the sampling rate like others have said is hard to tell a diff...
Old 04-06-2005
reshp1's Avatar
1K Silver Member
I don't agree with this. In the final product you will have mixed it such that you are utilizing the full dynamic range. When recording at 16bit, you'd have to record everything as hot as possible to acheive this. What you are most likely doing is recording a track and then upping the gain later in the mix, either with the fader or compression, which further emphasizes the quantization error of low bit size. It's much better to record at 24 bits, because even at very low recording levels you have better resolution than you end format. You can they manipulate and add gain without fear of large quantization errors.
Old 04-06-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
24, yes. 96, not so much.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 04-06-2005
HangDawg's Avatar
HangDawg HangDawg is offline
bUnGhOlIo
HangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond reputeHangDawg has a reputation beyond repute
Please don't propagate garbage like this just because it's what you've bought into.
http://www.garagerecording.com/images/lava22.gif
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
  #12
Old 04-06-2005
NL5's Avatar
NL5 NL5 is offline
Unpossible!
NL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond reputeNL5 has a reputation beyond repute
I could swear that i read a white paper on this, and that is completely wrong. There is actually a problem doing that, in that it causes artifacting that is eliminated by converting from 96 instead of 88.2 - does anybody remember that article - I'm pretty sure it was posted on here.
Anyway, I record at 24/48.
They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. -B.F.
  #13
Old 04-06-2005
HangDawg's Avatar
bUnGhOlIo
I think the MATH involved with sample rate conversion from 88.2 to 44.1 is more than just dividing by 2.
SELECT W.People
FROM tbl_world W
WHERE W.Clue = TRUE
NO RECORDS RETURNED
  #14
Old 04-06-2005
reshp1's Avatar
1K Silver Member
What more would you have to do besides drop every other sample? Maybe I'm just oversimplifying it, is there a "dither" for down sampling?
  #15
Old 04-06-2005
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Here's a useful article. The gist is take advantage of 24 bit when recording, and use the sampling frequency that your final product will be.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
  #16
Old 04-06-2005
amra's Avatar
amra amra is offline
1K Silver Member
amra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond reputeamra has a reputation beyond repute
I read an article the gist of which was that you needed approximately twice the amount sampling resoultion that you are trying to capture. I don't remember the details but I will try to find the link. Has anyone read or heard this before?
Amra
  #17
Old 04-06-2005
Farview's Avatar
Amra
That is that whole Nyquist thing that was discussed earlier.
Jay Walsh
  #18
Old 04-06-2005
MadAudio's Avatar
Damned if I do
Amra - you're talking about the Nyquist theory which states for lossless audio your sampling rate should be twice the range of human hearing. It has nothing to do with bit depth.
And I spent so long typing this that Farview beat me to it!
  #19
Old 04-06-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
96k?? ha!! that's for pussy stuff
i do all my recording at 192!!!! I mean, can't everyone hear around 96,000Hz??? hmmm, maybe it's just me.
www.redlabaudio.com
  #20
Old 04-06-2005
giraffe's Avatar
giraffe giraffe is offline
i love negative rep
giraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond reputegiraffe has a reputation beyond repute
yes 24 bit
i'm not 96 capable but i really like the idea of it because it is the point at which thare are 5 points on a 20k wave. i know not everyone can hear that hi, but the math looks good.
  #21
Old 04-06-2005
boomtap's Avatar
Dedicated Member
That is interesting and probably all true, but when I do this side by side in a class A studio, I just don't get this amazing recording when compared to 16bit. By the time it gets to mastering you just can't tell that the mix was 24 bit. I think that the very best equipment with the very best engineers, and the very best mastering house might be able to squeeze some extra out of 24 bit, but for the average project going to CD I just don't think you will be able to. I say do it if you want to, no big deal it won't hurt, I just don't think you will be gaining much.
If I polled 100 people and took 2 song versions 1 16 bit and 1 24bit(whole process), I bet that 100 of them could not pick out the diffrence. I mean people listen to music in thier cars, and on crappy headphones that don't reveal the clarity, and the rest of them can't tell FM from CD. Shoot AAC and MP3 rule the world now adays.
In short 24bit is better, but it is so minor that nobody cares. Until they can send sound direct to your brain with no sound pressure or cables, I think we are not going to see overwhelming advancement in sound technology.
  #22
Old 04-06-2005
amra's Avatar
1K Silver Member
Sorry, I meant sampling rate, not resolution. I wasn't talking about bit depths.
In any case I found the article I mentioned, and it is pretty interesting and explains the nyquist effect in terms us mere mortals can understand:
http://www.digitalprosound.com/Htm/S...ap2_Apogee.htm
  #23
Old 04-06-2005
Bob's Mods's Avatar
Bob's Mods Bob's Mods is offline
Force of Nature
Bob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond reputeBob's Mods has a reputation beyond repute
I believe the current wisdom is to record in the sample rate of the final product.
Bob
May You Live All The Days Of Your Life
  #24
Old 04-06-2005
ds21 ds21 is offline
Force of Nature
ds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond reputeds21 has a reputation beyond repute
But what if you want to archive for the future or even DVD, do you really want to convert it up from 16 to 24, or at least start with 24 and be safer, that is unless you don't have the HD space or CPU to handle it, that's the only rational reason to go with lower resolution. Of course this is MHO.
True Creation Comes Of Nothingness
-Winner Mix Contest 8-
-Winner Mix Contest 11-
  #25
Old 04-06-2005
altiris's Avatar
altiris altiris is offline
Force of Nature
altiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond reputealtiris has a reputation beyond repute
what about 32 bit floating? Is it better to record a 32 bit, 32 bit floating , or 24 bit rate? Cubase default is 32 bit floating. Should I change it to 24 bit. If so, why?
PC recording, not for the fence-sitters Diragor Digital Recording & Computers 11 02-28-2006 17:26
24/96 or 16/44.1 recording? BuildingStudios Recording Techniques 9 11-28-2002 02:03
Recording audio with Audiophile 24/96 FiVeL Digital Recording & Computers 8 03-22-2002 20:59
THE DAVEMANIA COLLECTION Glorifies HOME RECORDING and ANALOG! A Reel Person Analog Only 3 12-15-2001 01:14
