Old 04-04-2005
Scrubucket7's Avatar
Scrubucket7 Scrubucket7 is offline
Repeal The 19th
Scrubucket7 has much to be proud ofScrubucket7 has much to be proud ofScrubucket7 has much to be proud ofScrubucket7 has much to be proud ofScrubucket7 has much to be proud ofScrubucket7 has much to be proud ofScrubucket7 has much to be proud ofScrubucket7 has much to be proud of
Question phasing
so...ive been reading alot in preperation of finnaly being able to start settin up my project studio soon. Just tryin to refresh my memory on this stuff after a long break of just writing music...anyways, phasing, it seems pretty hard to get around. I know the 3:1 rule, dont completely understand how to apply it to more complicated applications (like, 7 mics on a drum set, or a condensor and a dynamic on a guitar amp at two different distances from the amp). But anyways, could tell me, what are the best ways of making sure your mixes dont suffer from the evils of phasing problems? Also, am i going to have an issue with getting the mics for different drums (high tom, low tom) in phase, or just two mics recording the same source (overheads)?...assuming there wont be too much bleeding.
The illest punk band in the world son - www.bobhopepunks.5u.com
Old 04-04-2005
ecktronic's Avatar
ecktronic ecktronic is offline
Mr Mix and Master Man.
ecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond reputeecktronic has a reputation beyond repute
Phasing from drum kits is complicated but simple!! If you rcord in a really small room the reflections off the walls can cause phasing. But apart from that phasing problems are easy to overcome usually. Once tracks are recorded, for example a guitar amp recorded with 2 or three mics, all you have to do is match up the waves in your editor so they are in phase. Leave one of the waves as it is and nudge the other two or three so that the peaks and troughs match up as closely as you can. Zoom right in on the waves to do this. You should only be moving each track a very small amount to get the tracks to be in phase.
Million dollar ears.
CRYSTAL MIXING
MY BAND
Old 04-04-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
If there isn't too much bleed, the phase won't matter. Use an xy araingment for the over heads and just mic up the drums. If you have a problem after you recorded it, it is easily fixed.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 04-04-2005
Repeal The 19th
one slight problem...
im gunna be recording into my mixer, then out to my 8 track stereo or mono, depending on the song. Im not using a computer, and if i do (i use acid pro usually) i wont be able to do that because itll be on one track. So is there any techniques other than, move mics around until it sounds good, that i can use to speed up the process?
Old 04-04-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
easiest way is to record a practice take and then zoom in on the wave form and physically look to see if the waves are out of phase.
second easiest way is to just flip the polarity on that track and listen to which one sounds better
third easiest and probably the more correct way...is to move the mic around until you get the sound that you want.
start learning what phase sounds like and then you'll be able to hear all the time it happens.
www.redlabaudio.com
Old 04-04-2005
Repeal The 19th
could someone please send me a diagram of this?
Old 04-04-2005
Farview's Avatar
use the least amount of mics on the drums as you can. Less mics, less chances of phasing. If you have a 4 piece kit, overheads in xy - mic inside the kick - mic on snare, close with the back pointing at the hi hat - mic on the high tom about an inch off the head - mic on the low tom about an inch off the head. That should do it. The less bleed you have the less phasing problems. Always do the drums in stereo, that will help as well.
Jay Walsh
preamp causing phasing issues? bennychico11 Recording Techniques 8 02-09-2005 22:05
Drum overhead phasing jonhall5446 Mixing / Mastering 9 08-04-2004 12:07
Phasing - Guitar Amps w/ Multiple Mics dizzlano Recording Techniques 6 02-25-2004 11:38
A/B / Phasing? tkingen Microphones 0 11-22-2003 19:34
Phasing? Rhino_Rick Newbies 2 08-13-2002 12:08
