Old 04-04-2005
loungepenguin loungepenguin is offline
Newbie
loungepenguin is on a distinguished road
humming on digital 8 track
Hi
I very recently bought a Zoom MRS802cd. I am having some humming noise problems with it.
Basically I plug my electric guitar in (with a brand new decent £25 thick guitar cable), turn the input and recording levels up to the required point and there is a humming sound. This is cut down to almost nothing if I put my fingers across the strings.
I have also plugged my acoustic in. This has a home made bug built into it so I was not expecting it to sound amazing but the hum is really bad. This time though if I put my fingers over the input on the guitar the hum disappears.
If the cable is just in the machine’s input and not plugged into anything else there is a nasty buzz unless I touch the end of it.
I have tried turning off all other electrical equipment in my room but no better. I have trioed moving away from the machine but still no good. The manual says I might need to ground the recorder. There is a little screw under the machine at the back and it says to use this to ground but does not mention how.
I had a little search on how to do this but nothing that I saw seemed to explain simply to a newbie how this is done.
Any help would be very appreciated!
Thanks
Old 04-04-2005
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
That humming is not a problem with the Zoom, but it's a ground issue - possibly on the wiring of your guitar -- but ALL guitars hum and buzz a little, especially with high gain... it's the nature of the beast. (It's also another benefit to mic'ing an amp - no chance of a ground loop between the instrument and the recorder!)
Old 04-04-2005
Newbie
Do you think one of these would fix it?
http://www.samedaymusic.com/product--BEHDI100
Old 04-04-2005
It could - IF the problem is a ground loop between the recorder and the guitar -- if it's a wiring issue on the instrument itself, it won't help.....
Humming from grounding problems can be tricky to diagnose and fix......
Old 04-04-2005
DonF's Avatar
DonF DonF is offline
Call Me "Grandpa"
DonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond repute
I don't understand how you could have a ground loop involving an instrument that is not grounded. It sounds to me like the instruments are picking up some stray EMF. loungepenguin, do you by any chance live under or near high-tension power lines?
Old 04-04-2005
The hum stops when he touches the strings -- which means the circuit is finding a ground through HIM -- that's a ground loop........
Old 04-04-2005
DonF's Avatar
Call Me "Grandpa"
I've heard of ground loops causing hum, but I've never heard of a ground loop stopping hum. I guess there's a first time for everything.
Old 04-04-2005
Newbie
No big power cables near me. I could try getting what has been suggested but I would like to try it first.
Someone else also recommended some kind of wristband that gets attached to the bridge of the guitar. Not sure about that though.
Any help on this is much appreciated
Thanks
Old 04-04-2005
A ground loop occurs if a signal can find its way to ground through multiple points. Some of those points may not be the best path to take (such as the singer getting a shock from a mic on stage).... same with the guitar. Something in his signal path is not grounded properly... and when he touches the strings, he's giving the signal a ground to go through - unfortunately, it's through HIM. When there's no anomaly in the circuit, he won't notice anything, but if something goes wrong and he happens to be the ground path - that can be a dangerous situation......
I don't know where you got the idea I said a ground loop "stops hum"... the term "ground loop" simply defines the fault condition that occurs with an electrical signal having multiple points to ground to - and one of its symptoms is a hum being heard through the audio signal of the affected circuit. What stops the hum is correcting the circuit fault (and finding that fault is what is sometimes difficult to locate and/or diagnose!)
Old 04-04-2005
xtjdx xtjdx is offline
Senior Member
xtjdx is on a distinguished road
Blue Bear is the man.
I agree, it sounds like a grounding issue. In my last band's practice space, the whole unit was ungrounded so we had to play on carpet, otherwise you'd get a nasty lingering current on the concrete. It was incentive to get the set done quickly, but there were some awful shocks back in the day.
This had almost nothing to do with anything.
This is beautiful.
THIS IS ART.
I love Pig Destroyer.
Old 04-04-2005
DonF's Avatar
Call Me "Grandpa"
*DonF shakes head*
A ground loop is an electrical fault wherein an audio circuit (any circuit, really, but it's audio we're concerned with here) contains more than one distinct path to ground. If the paths to ground have different impedances (which they almost certainly will), current will flow at the mains frequency, which is audible as hum. So we agree on the definition of "ground loop".
Blue Bear, you said, "The hum stops when he touches the strings -- which means the circuit is finding a ground through HIM -- that's a ground loop." The only way I can read this is, "he touched the strings, creating a ground loop, which stopped the hum." I'm always looking to learn something new, so I pointed out the seeming inconsistency, knowing that you would set me straight. Thank you for not disappointing.
I think what's going on is that loungepenguin's body is seen by the circuit as a "pseudo-ground" in the sense that it is acting as a source of electrons. (If he's barefoot on a concrete floor, which he didn't state, my opinion would be different.) The fact that there's hum even with an unconnected guitar cord makes me very confident that what we have here is a stray EMF problem rather than a ground loop.
Providing a true ground in this situation might be just the ticket. Connect the grounding screw on the zoom to a good ground, like the center screw on an electrical outlet cover plate. If you're not confident of the wiring in your building, proceed with caution. Especially if you're barefoot on a concrete floor!
  #12
Old 04-04-2005
*DonF shakes head*
Yup!
The way I meant that statement was "The hum stops when he touches the strings -- which means the circuit is finding a ground through HIM -- that probably means he has a ground loop somewhere."
You misinterpreted what I meant by that last part of the statement! Glad we cleared this up!!
  #13
Old 04-04-2005
mattamatta's Avatar
mattamatta mattamatta is offline
Force of Nature
Location: I told my friend that his anus was so big, that he had to get a restraining order for the local caving club.
mattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond repute
It's lavos feeding off the energy of the earth!
  #14
Old 04-05-2005
Newbie
wow - thanks for all the help! good to get a discussion going!
It's definitely getting some kind of grounding thing going through me. The cable buzzes when it's not plugged in unless touched an on my acoustic the hum stops if I touch the input. (the bug inside is just connected to wood and not the strings). My Electric is a pretty decent £300 Tele and I have never had problems with it. Strangely a Mic plugged does not cause as much as a buzz.
I tried to ground the unit but I can't seem to find anything to ground it to. If I attach a wire to the screw and touch the other end it makes no difference. I am 2 floors up standing on carpet, and the zoom is on a wooden shelf.
THe unit that I mentioned has a "ground lift" - does anyone know what this is? Do you think it might help? I might just get it anyway as I am sure that it will get rid of a bit of the buzz anyway. I just need to get an XLR cable for it.
Any help very appreciated!
Thanks
  #15
Old 04-05-2005
Newbie
Just read the review of the unit (http://www.samedaymusic.com/product--BEHDI100 ) and it says "Ground Lift switch isolates grounding circuit for hum elimination"
What do you think?
  #16
Old 04-06-2005
Newbie
What fun! Spent hours last night trying to get to the root of this with no joy.
I moved the zoom downstairs, out of my room and plugged it into one socket with nothing else. No other electrical equipment near it.
I bought a Behringer DI100 Active Direct Box and an XLR to XLR cable. As far as I could tell this did nothing. I pressed the ground lift button and still nothing. I pressed one of the Switchable input attenuation which allows input levels of up to +50 dBu – this seemed to work except the guitar went really quiet so I had to turn the volume up again and back came the buzz.
One weird thing though was that if I put my hand on the DI box the buzz lessened but not as much as if I put my hand over the strings.
I then got a friend to come around and tried it with a different guitar lead – same problem.
We then tried it with his guitar which is really expensive and there was less of a buzz and the guitar sounded a little louder but the buzz was still there and again when you put you fingers over the strings it pretty much went.
We then tried grounding the Zoom using a wire and the screw at the back of the unit. The manual is not very helpful in this but we connected the wire to the zoom and then tried putting the other end on radiators, walls, the floor and finally us – this all made no difference the only slight difference was if you pinched the other end of the wire with your fingers continuously you could hear a slight clicking sound but nothing else. You could remove the hum by connecting the same wire to the bridge of the guitar and pinching the other end.
One suggestion I have had is to use something electricians use to (I assume) stop static – connect a wire to the bridge and the other end to a wristband around my wrist. I have a feeling this would work but it seems a bit weird to have to do this and almost dangerous! Pretty rock and roll way to go I suppose though!
Basically the electric is useable as I touch the strings almost all the time but if you are only touching one string the buzz is louder than if you are touching all of them so it’s still there. If I use my acoustic the buzz is always louder than the sound (I know my acoustic bug is never going to be brilliant) unless you touch the input where by the buzz almost disappears.
This leaves me thinking – is the Zoom not working properly or is this because (in past experience) Zooms are always not brilliant and this is just the way things are?
Any help on the desperately appreciated!
  #17
Old 04-06-2005
Newbie
oh yer forgot to mention something else - with the guitar cable plugged into the zoom and not my guitar there is a buzz but if I move the end of the cable that would be plugged in my guitar within one inch of the unit the buzz goes! strange!
  #18
Old 04-06-2005
DonF's Avatar
Call Me "Grandpa"
Originally Posted by loungepenguin
...We then tried grounding the Zoom using a wire and the screw at the back of the unit. ... [W]e connected the wire to the zoom and then tried putting the other end on radiators, walls, the floor and finally us....
Did you try a cold water pipe? They usually make a good grounding point.
Thanks for the update. Stick with it!
Don
  #19
Old 04-06-2005
Newbie
I tried the radiator, but in my room at least there is nothing else. I am going to try one of the wrist bands later.
Also, I emailed the people I bought it off and they said that it is unlikely that it is the Zoom and to try it in someone elses house. Going to try this later but if it works in someone elses house and not mine then that is not good. Maybe I'll have to buy a new house to go with it!
much appreciated
  #20
Old 04-06-2005
DonF's Avatar
Call Me "Grandpa"
I tried the radiator...
Yes, I understand. Just wanted to make sure you understand that a cold water pipe is special in that it generally has a much more direct connection to the earth than any hot water pipe or radiator.
Have you ever had this problem with any other piece of equipment, like a guitar amp? Or does everything else work fine?
  #21
Old 04-06-2005
Newbie
everything else works fine. I used to have a Korg electribe and that had no buzz even with my guitar plugged into it. My amp seems OK too.
Which Digital recorder can do these things? JimmieJazz Roland, Boss, VS Series Forum 8 06-29-2006 10:38
I Need Help With Editing. Key Rogue Cool Edit Pro / Adobe Audition Forum 14 11-30-2005 00:37
track digital ---> mix to tape? tryptophan Analog Only 2 04-03-2005 22:21
FS - Yamaha MD8 digital 8 track Supercreep Free Ads for Music / Recording Equipment 0 03-22-2005 12:01
Analog vs. Digital Need help.... LTG Analog Only 32 09-16-2004 17:00
