US-122 Effect Sends?
The instruction manual makes no mention of how to use the effect send jacks on the front of the unit. Are they even sends? Let's say I wanted to add an outboard compressor. Anyone have a clue?
Thanks, JD |
So what then is the difference between going: mic -> comp -> regular input
versus doing that? I don't understand where in the signal chain the effects are going basically if you use those. Also, it seems that if you want to add effects to something mic'd then you lose the ablilty to use the XLR inputs on the US-122. Did I totally miss the boat on this somewhere? JD |
http://www.musiciansfriend.com/srs7/...se_pid/336120/ |
Thank you!!
That explains everything. I figured that it was a regular 1/4" mono plug, so nothing made any sense. Now I see that it's actually a 1/4" stereo plug and that the send and return are really going through the same cable. Very very cool. Muchas gracias!
JD |
| Can you hear an inserted effect as you are recording an audio track? | Nigie | Cubase User Forum | 3 | 10-04-2003 21:00 |
| What is that effect on vocals called..... | kostas04 | Newbies | 12 | 09-09-2003 19:37 |
| ev-5 to control leslie effect? | erichenryus | Keyboards and Sound Modules | 1 | 09-04-2002 23:40 |
| busses, sends, submixes...long post | jrich | Cakewalk / Sonar Forum | 8 | 07-23-2002 16:18 |
| Any ideas on good and cheap Effect processor? | Sam420 | Mixing / Mastering | 3 | 06-03-2002 15:45 |
