Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 04-02-2005
vintagetobes's Avatar
vintagetobes vintagetobes is offline
Senior Member
vintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to beholdvintagetobes is a splendid one to behold
Problem with midi :-S
Hey, iv just got into using midi properly, mainly for my school work. Basically, when i use for example the vsti edirol quartet i think its called, when i change the particular type of instrument it is using, it changes back to the original one when i replay the song. e.g. steel string guitar -> southern guitar. It allways goes back to the default one so i have not way of keeping it. Any ideas? Thanks
Old 04-02-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
Well you didn't specify what type of sequencer you are using to playback your MIDI files, so it'll be hard to give you specifics. With 99% certainty I'd say this is caused by unwanted program change messages. Either open your event editor (List Editor) and remove any program change messages, or set your sequencer to filter program change messages. This should do the trick. For more specifics, you need to tell us what you use, or refer to your documentation.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 04-02-2005
Senior Member
oh im sorry, i probably posted this in the wrong place making it look like a hardware synth. Its just a vst instrument set which i use in cubase SE. Thanks for the help
Old 04-02-2005
The Dark Knight
OK select a MIDI part and open List Editor from MIDI menu. In this new window on the top left is a dropdown box named "Mask". Click the button to the left of it (The one with an eyeball, checkmark, and X). Now a new row appears. Check all the options except Program Change (Effectively hiding everything else). You can now highlight what ever remains (Program Changes) and delete them, or alter them as you see fit. Repeat procedure for each MIDI track.
Old 04-02-2005
Senior Member
ta very much for that. il try it a bit later. back to my revision :-S
Old 04-02-2005
Senior Member
hey, thanks that worked, exept for the bass guitar, when i change the volume in the soft synth it works if i do it whilst it is playing, but then when i play from the start, it goes back to full volume on it's own. even though the actual track volume selector stays the same aswel, it just ignors it until you move that. Hmmm, thanks a lot for the other instruments though.
Old 04-03-2005
The Dark Knight
To delete volume data, use the same procedure above but leave Controller unchecked and look for Main Volume data (CC7 is volume control, but Cubase calls it Main Volume). And delete it as neccesary.
drum machine, Cakewalk, USB MIDI interface, argh 55337 Newbies 14 03-09-2005 16:41
problem in MIDI jerberson12 Newbies 1 07-19-2003 03:10
i'm having a midi sync problem... roostmusic Cakewalk / Sonar Forum 21 02-14-2003 02:22
Cubase SX/ Triton MIDI problem pumpkin MIDI Mania 0 01-29-2003 16:39
Midi and Sound Card problem Cal D Digital Recording & Computers 5 11-05-2002 19:50
