Old 03-31-2005
O.D.R.S. O.D.R.S. is offline
Newbie
O.D.R.S. is on a distinguished road
Pre Fader Listening
Greetings! I am not new to recording, but I have a question about PFL. My console manual (MX9000) says to set the desk level using PFL. The manual is kind of vague when it comes to explaining things. At what levels should the meters be hitting when in PFL and when not in PFL? I ask because when it's not in PFL, the meters don't seem as strong. Should the individual tracks be hitting at 0dB or just the master? Maybe I'm doing something wrong. Sorry if this sounds stupid. Thanks
Old 03-31-2005
AlexW AlexW is offline
Force of Nature
AlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to behold
Pre-fader levels will essentially show the level coming in off your preamps, before they're adjusted by the faders on your mixer. Depending on what you're recording too and how, you generally want your preamp levels to have a decent gain (upper 2/3 of your meter). When you switch out of the PFL mode, the level will naturally drop unless your fader is up at unity gain.
Old 03-31-2005
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Most FPL signals are affected by EQ as well.
Using mic pre that, in turn, goes through onboard pre of DAW...pointless? centurymantra Microphones 20 03-19-2005 11:59
Did you know that you probably just are listening to 19 or 18 bit sound? Boray Roland, Boss, VS Series Forum 48 02-04-2003 09:45
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
Do I really need that master fader during final mix down...It kills my volume! Trash Man Mixing / Mastering 14 11-16-2000 09:58
Mic Pre Listening Party pglewis Other Equipment and Reviews 1 05-28-2000 02:21
