Old 03-31-2005
Myriad_Rocker's Avatar
Myriad_Rocker Myriad_Rocker is offline
Registered Text Offender
Myriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond reputeMyriad_Rocker has a reputation beyond repute
Is there a rule on how much to double?
2 guitar parts....double both, making 4 tracks...send one to the left and then one to the right...on the chorus, quadruple the tracks....
is that over kill?
Should I think about reamping for laying additional amps on? Or will that just create phase issues?
Myriad Rocker
My Web Design/Production Company: Myriad Productions
My Band: Black Leaf Clover
Originally Posted by theblackBay View Post
I’m currently "one" of the best song writers in the world
Old 05-01-2005
bump
Myriad Rocker
Old 05-01-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
There are no rules. Go with what sounds good. However, too many guitars will actually tend to make a mix sound smaller, rather than bigger, because you'll have to keep the volumes so low and deal with all the phasing/eq problems. Start with one part panned left and a doubled part panned right. If you are going to layer guitars, try playing the second part with different chord voicings so there is less overlap.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 05-01-2005
Rokket's Avatar
Rokket Rokket is offline
Sgt Floyd Pepper
Rokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond reputeRokket has a reputation beyond repute
Plus try what I do: play the parts with different amps, different guitars if you can. That can fatten it up without too much of a phase issue along with playing the chords in different voicings...
The hardest part of being a bartender is figuring out who is drunk, and who is just plain stupid.
Old 05-01-2005
screws screws is offline
Junior Member
screws is just really nicescrews is just really nicescrews is just really nicescrews is just really nicescrews is just really nice
Add to that, different mics, different placement of mics, different tones on the amp, play the heavy part with a heavy sound, layered with same part played with a clean sound and a slightly crunchy sound. Same part played through same amp, but put in the bathtub and miked up with a condensor from 6 feet away, 2 feet away.
Mic the strings of the electric guitar being played in one room at the same time you mic the amp in a different room. Use a condensor on the strings to get a really brilliant sound. Use a few milliseconds of delay on the string track to time-align it with the amp track. Blend the two to give the amp track better definition.
Borrow as many amps as you have guitarist buddies. Record a part through a D.I. and get a reamp box. Then run the track through each amp with different mics and stuff.
Put a small amp in a cardboard box and mic it from inside and outside. Put it in a bass drum. These kinds of nutty experiments were why the Beatles discovered so many cool sounds - like a guitar through a leslie.
Experiment! Find YOUR cool thing, and then tell US!
S. Cruz
Cruzified Music
Florida
Old 05-01-2005
chessrock's Avatar
chessrock chessrock is offline
Banned
chessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond reputechessrock has a reputation beyond repute
Yea, didn't you hear about that rule ?
You're getting in to dangerous territory, there. You don't wanna' know what happens if you break the rule. Believe me. Go back and reduce the track count immediately by one track.
Either that, or you could just add one more. You see, the rule states that there must be an odd number of layers when tracking guitar. It has to do with odd and even-order harmonics in phase relationships. If you go ahead and do one more and pan that one straight-up center, you should be fine.
Old 05-02-2005
grn's Avatar
grn grn is offline
www.michaelchagnon.com
grn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond reputegrn has a reputation beyond repute
yes, when doubling, always make sure you have three. so says the rule. but personally I like everything of mine in doubly.
Michael Chagnon
Twitter
MySpace
Old 05-02-2005
I love how a lot of you guys are true to your asshole roots.
Myriad Rocker
Old 05-02-2005
scrubs's Avatar
Not of sound mind
Originally Posted by Myriad_Rocker
...asshole roots.
Alright, that's totally my new band name! Scrubs and the Asshole Roots.
My tunage
Old 05-02-2005
chessrock's Avatar
Banned
Someone just started another thread about roots.
Double track vox, yeah or neh?? the dude Recording Techniques 30 05-25-2007 05:20
2 double track or not 2 double track vox makes Recording Techniques 10 01-27-2005 16:04
double double terrible_buddhi Mixing / Mastering 0 09-04-2003 09:11
Mac vs PC bdemenil Digital Recording & Computers 51 03-22-2002 15:31
Double Track Vocals? Brian01 Recording Techniques 17 03-07-2002 21:28
