cubase sx2 - removing a template ???
thanks for all the help on the last question- here's a new one.
Is it possible to remove saved templates from the new project/template list window. I saved some useless ones and would like to delete them to avoid confusion. The stock templates are easy to find and delete but i cannot find these on either drive??? all help is appreciated.-thanks |
Wow. That's a good question.
This is beautiful. THIS IS ART. I love Pig Destroyer. Last edited by xtjdx; 03-30-2005 at 19:18.. |
I believe that there is a folder inside the Cubase SX application folder called "templates". Once you find that there should be files for each individual template. Delete the ones you do not want and they should disappear as options when opening a new project.
That folder only has the initial templates. I couldn't find custom ones anywhere either. I'm going to do a registry check when I get back home.
This is beautiful. THIS IS ART. I love Pig Destroyer. |
Just create another template and then see where the program saves it.
Carter MCF Productions |
I did that last night and it wasn't anywhere on the drive.
i've created new templates and checked everywhere... i'm guessing registry or embedded in another file????
I checked registry. Can't find anything except from my previous file searches. This is odd.
You could try this: run Total Uninstall before you add a template, then after. It will show you what changed in your drive and in your registry.
Total Uninstall (freeware) http://www.martau.com/tu2.php Andrés EDIT: I read this: "Templates are now stored in the user's Documents and Settings/<username>/Applicatio*n Data/Steinberg/Cubase SX/Templates folder. Templates can still be accessed from the original Templates folder, for all users, but you cannot write templates to that location. You can, of course, create a template then copy/move it to the original location, providing you have permissions to do so. All a bit of a mess though. " It also says that depending on your settings, it's created hidden.
"A woman in a bicycle, with a straw hat, is the most flagrant violation of the laws of aerodynamics." (Dr. Vaporeso) Last edited by cordura21; 03-31-2005 at 14:23.. |
cordura21... you are the winner .... thanks for the info.. i found all my unneeded templates and deleted them... heres some rep points for you..
thanks for the help everyone |
Thats good to know. I guess I had never deleted one of the templates that I made, but have always gone in and deleted all of the stock templates
#12
So, where were they hidden?
#13
Sounds like the user templates are buried in the "my documents" section of windows
| cubase sx2 -mix down problems | seismetr0n | Cubase User Forum | 5 | 04-01-2005 19:31 |
| multi-tracking in cubase sx2 | elementary | Digital Recording & Computers | 2 | 01-21-2005 18:36 |
| Cubase SX2 not spotting 24bit/48 capabilities...? | TDAS | Cubase User Forum | 0 | 10-03-2004 03:58 |
| Using midi to sync up my two pc's in Cubase SX2 | cadebusy | Cubase User Forum | 0 | 08-08-2004 19:49 |
| System Link in Cubase SX2 | cadebusy | Cubase User Forum | 0 | 08-06-2004 11:20 |
