Old 03-30-2005
scottboyher's Avatar
scottboyher scottboyher is offline
The King Of Nothing
scottboyher will become famous soon enoughscottboyher will become famous soon enough
Just bought some new outboard equipment and need help..
I bought a new dual channel mic pre and a dual channel compressor/gate (not a 3630)
Which comes first in the chain?
Mic > pre > comp/gate > mixer ?
Mic > comp/gate > pre > mixer ?
_______________________________
www.scottboyher.com
info@scottboyher.com
Old 03-30-2005
RobertN RobertN is offline
Dedicated Member
RobertN is on a distinguished road
Its probably mic>compressor>mixer
Old 03-30-2005
SonicAlbert's Avatar
SonicAlbert SonicAlbert is offline
Super-Sonic "Herb" Albert
SonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond reputeSonicAlbert has a reputation beyond repute
This one:
Old 03-30-2005
The King Of Nothing
Originally Posted by SonicAlbert
This one:
Excellent! Thanks..
Now it is Mic > Pre > Comp > Mixer.
I go from the mic to the pre with XLR...
What do I want to use to go from the Pre to the comp and the comp to the mixer?
Stick to XLR all the way through the chain or switch to TRS somewheres?
www.scottboyher.com
Old 03-30-2005
Track Rat's Avatar
Total Gear Slut
How about this
Mic> Mixer> Compressor patched to an insert. If you're using a mixer, it has mic preamps.
Mike
Old 03-30-2005
The King Of Nothing
Originally Posted by Track Rat
How about this
The prob with that is the cheap mixer, it doesn't have inserts and the pre's are terrible.. It is a cheap Alesis Multimix thing...
I only record alone so it only has two XLR and two stereo line in's. So I am adding a Comp and a Pre between my two cheap condensers and the mixer .. I think?
www.scottboyher.com
Old 03-31-2005
The King Of Nothing
Ok, I have to go Mic > Pre > Comp > Mixer because of the phantom power.
Now do you go down this chain with XLR or do you switch to a balanced TRS somewhere along the line?
www.scottboyher.com
Old 03-31-2005
xstatic xstatic is offline
Been Here, Posted That
xstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond reputexstatic has a reputation beyond repute
Stay XLR until your equipment forces you to go TRS. You want to go from the compressor to the Alesis through a line inout though so that may be where the switch to TRS happens. If you go in XLR to the Alesis you may be hitting the mic pre on the Alesis as opposed to the line input. That can still work, but probably won't be as clean and you may have a large gain mismatch. It all depends on how the Alesis treats line in's.
Old 03-31-2005
The King Of Nothing
Yep, never thought of that... Question answered.. Thanks!
www.scottboyher.com
Old 03-31-2005
Take a look at the Alesis signal flow schematics as well. It is quite possible that you are going through the preamps even when jacking into the line inputs.
Old 03-31-2005
The King Of Nothing
Yep, they are going through the pre's in XLR and TRS...
www.scottboyher.com
  #12
Old 03-31-2005
If the mixer has inserts you might be able to bypass the preamps by jacking into the inserts to the first click only. If the connector can hold the jack solidly enough this would work.
