Old 03-30-2005
DogFood's Avatar
DogFood DogFood is offline
Senior Member
DogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond reputeDogFood has a reputation beyond repute
Digital recording interface question
I am researching digital recording interfaces. I am pimping a Toshiba Laptop with a Pent 4 200+, so I've got that covered and could easily get a tower together if I needed more computer flexibility. Now I need to record a medium to large sized drum kit. That will be all the more mics I will be imputing at a time. I would prefer at least 8 imputs. What products/manufacturers have I missed?
Digidesign 002
motu
echo
mackie products
tascam
yamaha
Also is there a particular configuration that would be more powerful/flexible at the same cost? such as a mic pre 8 inputs with a lightpipe out to a sound card and add software and you get more for yer buck?
Old 03-30-2005
Elmo89m's Avatar
Elmo89m Elmo89m is offline
Force of Nature
Elmo89m is a jewel in the roughElmo89m is a jewel in the roughElmo89m is a jewel in the rough
if you had a tower you could get a m-audio delta 1010lt pci card its 229.00 and has 8 inputs plus some virtual inputs. you need your own preamps...or you could get a presonus firepod (firewire interface) it has preamps already and it has eigth inputs but its 599
Old 03-30-2005
aaroncomp's Avatar
aaroncomp aaroncomp is offline
1-20-2009
aaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond reputeaaroncomp has a reputation beyond repute
Thumbs up
I second the Presonus Firepod idea.
Old 03-30-2005
apl's Avatar
apl apl is offline
Stand Up Comity
apl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond reputeapl has a reputation beyond repute
Or the RME Fireface.
The fabulous Naiant Mics, perfect for acoustic instruments!
If you don't have DavidK's CD, you are a loser.
My tunes. Thanks!
NB
DA BEARS!
Old 03-30-2005
DogFood's Avatar
Senior Member
what advantage is there to a mondo soundcard with an 8 channel mic pre fire wire piece of hardware? more phantom power imputs? is the sound going to be cleaner? are there going to be data transmission problems with say a digi002?
Old 03-30-2005
AlexW AlexW is offline
Force of Nature
AlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to beholdAlexW is a splendid one to behold
I've never had data transmission problems with my Digi 002R. Basically you're paying for the I/O interfaces (analog, s/pdif, ADAT), preamps, and converters with any box. Firewire is a pretty effective way to transfer data to your computer and doesn't require a separate PCI soundcard interface. If it's an 002 you also get some faders to play with; and it can act as a stand alone digital mixer.
Old 03-31-2005
Elmo89m's Avatar
Force of Nature
a pci generally has the lowest latency but the firewire is right up there if not quite as good...yes on the pci card you would need your own pre's and phantom power...the firepod has that on all channels.
Old 03-31-2005
DogFood's Avatar
Senior Member
if I can allocate funds away from the hard ware I can dump it into mics. that is a good thing. would I expect any latency issues recording a full on 8 channel drum thang?
Old 03-31-2005
Force of Nature
Shouldn't be a problem.
New PC recording environment - poor quality with AudioBuddy interface lindamac Microphones 13 09-06-2005 09:19
Digital Recording Question / Mixer TermOne Digital Recording & Computers 8 03-14-2005 11:23
Recording Digital Drums Cheeky Monkey Drums and Percussion 2 02-11-2005 19:18
New PC recording environment (subtitle: problems with AudioBuddy interface) lindamac Digital Recording & Computers 5 01-01-2003 08:30
Analog vs Digital vs DAW Flames Recording Techniques 26 12-30-2002 17:25
