Old 03-30-2005
Karel Lootens's Avatar
Karel Lootens Karel Lootens is offline
Newbie
Karel Lootens is on a distinguished road
mixer gain setting
hello,
I've just received my UB-802 (yes, I went for the Behri since it sounded like the best deal for me) and I was wondering how to set up the gains in order to minimise the noise from the mixer.
I read the gain fitness article that was linked to e couple of weeks ago so i already know I should set the pre-amp gain so that the clip led doesn't come on at the loudest part of the music. I then reduced it a little further since I read the Behri's are only good for a limited amount of gain
I'm only using 1 mic channel, should i set all the other dials to minimum? or doens't that influence the signal (can't imagine that).
and since I'm only using one mono channel, how should I set up the gains? I mean, there is the channel gain and the master gain, where do I put both in order to get minimal noise wrt the signal?
thanks in advance,
Karel
Old 03-30-2005
Idgeit's Avatar
Idgeit Idgeit is offline
Dedicated Member
Idgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to beholdIdgeit is a splendid one to behold
Normally when ever im using a mixer, and only one or two of the chans, i always keep the other chans set to 0. To stop any noise that may appear.
- Idgeit
"Lets go with the milk....", "Lets go with the milk?", "Im sorry, could you bless me with some of your precious milk?" - Ricky, Trailer park Boys
Old 03-30-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
If it has meters, set the channel gain so that the meter reads around 0, still making sure the clip light doesn't come on. You normally have to solo the channel to make the meters read the channel gain.
Next set the master gain so that the meters read the same way (after unsoloing the channel)
This shoud translate into a good, safe signal with a minimum of noise to feed the next thing in the chain.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Attention Newbies: Copy and Save This For Reference!!! (Pt 1) Buck62 Newbies 11 03-27-2009 15:57
Attention Newbies: Copy and Save This For Reference!!! (Pt 2) Buck62 Newbies 12 04-25-2005 09:40
Help setting up External Mixer with Echo MiaMIDI. Change of POETS Digital Recording & Computers 6 02-08-2004 15:11
noob q: Gain Stages in my Preamp dirtythermos The Rack 0 01-21-2004 12:27
my recording setup - NEEDS HELP sykotic Digital Recording & Computers 12 10-06-2001 17:26
