Old 03-29-2005
ThePhoenix's Avatar
ThePhoenix ThePhoenix is offline
Newbie
ThePhoenix is on a distinguished road
this mic and preamps
http://www.musiciansfriend.com/srs7/...se_pid/273168/
that mic says it has an FET preamp. I planned on buying an M audio Dmp3. if that mic has a preamp in it, should i still get the Dmp3?
Old 03-29-2005
scrubs's Avatar
scrubs scrubs is offline
Not of sound mind
scrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond reputescrubs has a reputation beyond repute
Yes. All condenser microphones have some sort of preamp built in, but you still need another preamp to amplify the signal. The terminology is what is confusing. The mic's internal preamp (which runs on phantom power from your external preamp/mixer) is just enough to boost the signal along the mic cable to the preamp. The external preamp boosts the signal up to line level for recording.
"That was so terrible, I think you gave me cancer!"
My tunage
Old 03-29-2005
mattamatta's Avatar
mattamatta mattamatta is offline
Force of Nature
Location: I told my friend that his anus was so big, that he had to get a restraining order for the local caving club.
mattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond reputemattamatta has a reputation beyond repute
All condenser mics have a preamp built in because the diaphragm vibration results in a changing capacitancs, which in itself doesn't produce a signal that can be sent down a cable and amplified - so there are electronics built in that use the change in capacitance to output varying voltage and current.
Dynamics, on the other hand, dont need this sort of circuitry, as the motion of the diaphragm generates currents by nature.
Old 04-03-2005
remo_marbleblue remo_marbleblue is offline
Newbie
remo_marbleblue is on a distinguished road
What do you mean when you say a preamp is still needed to boost the condenser mic signal up to line level? I have to boost my dynamic mics just to equal the condensors, and turn the condenser mics volume down just to get an even mix.
Old 04-03-2005
c7sus's Avatar
c7sus c7sus is offline
Disenfranchised Member
c7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond reputec7sus has a reputation beyond repute
That's because the sensitivity of the condensor is greater than the dynamic.
But you still need to raise the MIC LEVEL to LINE LEVEL for your recording media to be able to make use of the signal, regardless of mic capsule type.
"dialing in" more "tube" in mic pre a.k.a how to use those 2 knob tube mic preamps junplugged The Rack 1 07-10-2004 20:50
The Mic Test Thread! Rhythmschism Microphones 41 04-30-2004 12:23
Mic preamps on Mackie 32x8 vs. Standalones? Orpheus The Rack 16 06-04-2003 18:32
NT1 Rode ? Ears Microphones 24 06-27-2000 09:16
