mono/stereo Jack
im confused! what's the diffrence. if im using the m audio delta 10/10 for the inputs do i want to be using stereo or mon jacks
many thanks jimmy |
mono TRS (balanced) cables are preferable
the inputs on the 1010 are all mono. inputs on a mixer or a soundcard will usually tell you if it's stereo or not. but generally only outputs on a soundcard are mono.
www.redlabaudio.com |
will it matter if i use stero jacks, will it effect anything in any way
well, they won't be stereo plugs
for your use, they will be considered TRS (balanced) plugs instead. They're only stereo if two separate L/R signals are being sent down the cable. It will just be a mono balanced cable. but don't try and plug in a stereo peice of gear with it into the 1010 jack...you'll lose the stereo
sorry im being a div here.
iv got a multicore that is 8 female xlr to 8 female jack, so this will be suited to use? ill still get the same affect as the an mono jack? |
Don't confuse the connector with the signal it is carrying. The connector doesn't care, you just have to know what you are plugging into.
i will be sending a mic signal down the cable in to the m audio delta 10-10
the other end of the XLR connector is a 1/4" FEMALE??
Where is you mic pre?
Won't work! You need to plug the microphone into a pre-amp (using an XLR-XLR cable) and then plug the output of the pre (which could be XLR or 1/4", balanced or unbalanced, but it will be line level) into a 1/4" input on the 1010. If the cable going into the 1010 has two black strips (TRS) the 1010 will think it's getting a balanced signal. If you use TS, it will be unbalanced. Since it is only ONE signal, it will be mono. I hope you didn't buy the 1010 before you had figured out how to hook everything up
| BBS Member Tutorials/Guides | chadsxe | Mixing / Mastering | 29 | 10-19-2005 11:37 |
| . . .yet another patchbay question | tlp | The Rack | 19 | 07-08-2004 13:56 |
| Specs VS840 Ex | BrettB | Roland, Boss, VS Series Forum | 9 | 01-14-2002 16:12 |
| Converting MIDI to WAV | AndrewSales | Cakewalk / Sonar Forum | 38 | 08-21-2001 22:31 |
