Old 03-29-2005
elko elko is offline
Newbie
elko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond reputeelko has a reputation beyond repute
Volume
Hi all,
Bear in mind I know absolutely sod all about computers/soundcards/mics...
I'm trying to record some rough, mostly acoustic demos, on a budget. When I say budget, I mean I have no money. I have a couple of mics (one shit, one PZM), and basically my problem is that I am recording straight into the soundcard, and the output is just way, way too quiet.
Having looked about on the 'net, I sort of understand why this is, but have no idea how to sort it. Do I need a pre-amp, or mixer, or what?
Any advice would be fantastic, cheers.
Old 03-29-2005
Tifstorey's Avatar
Tifstorey Tifstorey is offline
Guinea Pig
Tifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond reputeTifstorey has a reputation beyond repute
A Pre-amp is the ideal way to go to get your recordings higher volume, however, as you dont have any money there is another way. You can increase the volume once youve recorded it depending on what software your using. Normalize your recordings to around 90db to get it higher. That should work fine for you
Old 03-29-2005
Newbie
Using Logic 5.5 I tried Normalising some recording I just made, and the hiss would make it unusable for anything.
Old 03-29-2005
Tifstorey's Avatar
Guinea Pig
hmm, how much did you normalize it by? Try a little less. Hopefully someone else could answer this part!
Old 03-29-2005
Newbie
With Logic, as far as I am aware, there is no variable, it just Normalises so far until it doesn't clip, or distort, or whathaveyou. So I would guess that it's not the solution, I could be wrong though, I usually am.
I just found this:- http://www.prosoundweb.com/recording...shure/msc2.php, maybe that holds the answer but I really don't understand it.
Old 03-29-2005
Tifstorey's Avatar
Guinea Pig
Ill have a think and a read when im at work and post a reply when i get back tonight if someone hasnt already answered it for you. Hope you get it sorted!
Old 03-29-2005
Newbie
No luck so far, thanks for your help though.
Looks like I will have to start saving up. Either a pre-amp or a mixer that does the same job - any recommendations anyone?
Old 03-29-2005
Farview's Avatar
Farview Farview is offline
www.farviewrecording.com
Farview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond reputeFarview has a reputation beyond repute
normalizing a mic plugged into a line input will not work, it will bring up the background noise with it. you need to get a preamp, a small mixer has preamps built in. You might check to see if your soundcard has a mic input.
Jay Walsh
Farview Recording - And check out Farview's Rock Drum samples for Drumagog and now in .WAV format!!!
Old 03-29-2005
bennychico11's Avatar
bennychico11 bennychico11 is offline
bennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond reputebennychico11 has a reputation beyond repute
a microphone signal is incredibly quiet. this is why you need a preamp, to bring the signal up to line level.
m-audio makes some decent, inexpensive preamps...take a look at those.
www.redlabaudio.com
Old 03-29-2005
Newbie
Would this involve taking it out then?
Thanks to you both for the replies, as I say I am totally crap with everything to do with music recording except the actual music part.
Old 03-29-2005
you mean taking out your sound card?? no you shouldn't have to. if you have a stock soundcard that was included on your motherboard or came with your computer....there usually is a little drawing of a microphone on the card to indicate a mic input. A typical card will have 3 jacks on it. One for line, one for mic and the other one for a stereo output.
www.redlabaudio.com
  #12
Old 03-29-2005
Farview's Avatar
Nope. There is sometimes an input right next to the line input. It depends on your sound card.
Jay Walsh
  #13
Old 03-29-2005
Sanjanjoseph Sanjanjoseph is offline
Senior Member
Sanjanjoseph is on a distinguished road
there are many freeware and shareware recording and mixing programs that allow you to adjust your volume....for right this moment mixing....go demo hunting-adobe audition has a limit less demo for a week or so...
-i wanna see movies of my dreams
  #14
Old 03-29-2005
Farview's Avatar
I'm sure he has software, he needs a mic preamp.
Jay Walsh
  #15
Old 03-29-2005
Rockr56's Avatar
Rockr56 Rockr56 is offline
More guitar please...
Rockr56 is on a distinguished road
And do not use the mic input. Use the Line In. After you get a pre amp, of course.
  #16
Old 03-30-2005
Newbie
Yeah I have software, it's not the problem.
Thanks for the help guys - do even the cheapest mixers have pre-amps?
  #17
Old 03-30-2005
Tifstorey's Avatar
Guinea Pig
I got a Mackie desk which im selling cheap!1402VLZ has 6 pre amps hehe
  #18
Old 04-06-2005
Newbie
Sorry to bump this thread back up, but I tried using the preamp that came with my friends Minidisc mic, and both that mic and my PZM are still far too quiet when recording to PC. However, they both seem to work fine when recording onto a minidisc player, so I can only assume it's the PC.
Any other ideas before I start saving up for a decent PC (which I will have to eventually anyway, mine is fairly crap)?
  #19
Old 04-06-2005
it's not the computer. the computer has nothing to do with analog sound...it works with digital. it's your soundcard/preamp. you need a QUALITY preamp. what is this minidisk preamp that your friend had?
www.redlabaudio.com
  #20
Old 04-06-2005
Farview's Avatar
Consumer home Hi-Fi stuff won't get it done. You need to step up to something that was made for doing what you are doing.
Jay Walsh
Volume Control? Foxdog175 Recording Techniques 8 06-25-2004 09:30
Help with a little mixing term... pM of impk21.co Mixing / Mastering 15 12-08-2003 13:53
apparent volume vs. actual volume? cordura21 Mixing / Mastering 11 04-27-2002 03:41
Let's talk about normalization. Eurythmic Digital Recording & Computers 18 04-07-2000 14:50
