Fostex B-16D issues
Ok, maybe I got what I paid for this time.
It's a Fostex B-16D, 16 track 1/2" tape machine. For those of you curious bout its features, here's the jist: One speed - 15 ips Dolby C NR (whether you like it or not, can't be turned off) 2 head design (making calibration of rec levels and bias nearly impossible) I really don't care about the above limitations. What's bugging the crap outta me is that the electronics are noisy. When listening to the tape-outs on my mixer, at modest, unity levels, and turning the tape machine on, an incriminating hiss protrudes through my monitors. It's not my mixer. I'm 150% positive that the tape out circuits are all noisy. It's not bad, but multiply it by 16, it's pretty annoying. Also, my tracks sound like raw tape (maybe worse). Is Dolby C Noise Reduction supposed to WORK, or not? On top of the noisy electronics, there's TONS of tape hiss. Maybe it's the heads. THey're evenly worn, but it's a bit flat. THey have shape, but, you know. a bit of wear.......... I'm very tempted to sell it for a 38, or maybe a 48 or a 58. I'd much rather have 8 good tracks than 16 noisy tracks. Is there anything that I, the pissed off user that's handy with tools, can do besides sell it, or pay an arm and a leg for 16 tracks worth of gates? I don't want to have to transfer the tracks to a digital domain just to clean them up. -callie- |
And just so you don't think i'm crazy...
I paid $450 for the thing.........
The B-16 was Fostex' first foray into the 16 on 1/2". It's not the best of the line, but I wouldn't think it should be that bad. Dolby C is quite effective and preferred by many over dbx.
Someone may have fiddled with it that didn't know what they were doing and set the playback amps too high. Dolby doesn't work right if input and output levels are out of whack. What kind of tape are you using? Do you have a manual with setup info in it?
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 |
I'm using quantegy 456.
There's no manual. But I took it apart and figured out where the cal tweakers are. Just need a cal tape. That's a possibility. I'm the 3rd or 4th owner, and who knows what the 1st or 2nd owners did w/ calibration. -callie- |
Should I set the operating levels to +6? +5? +4? +3?
I know that with DBX, 456 tape needed to operate at +3dB. What kinda headroom is needed with Dolby C on 456? |
456 is the right stuff for that machine. Another possibility is that someone reset the unit for a lower output tape, so 0 vu is not as hot as it should be.
Or the heads are so badly worn everything is tweaked to the max. Here's a link with calibration portions of the B-16 manual. It's a little annoying being in jpg rather than pdf... but hey, it's free. http://synthetizer-sche.chez.tiscali.fr/listtape.html
You Rock. thanks. I'll go ahead and get a cal tape and try it out.... wish me luck.
Except that I need a test tone generator, and an oscilloscope. I'll have no problem obtaining an oscilloscope, but I don't even know where to start looking for a test tone generator. Looked on ebay, and they were all cheapo telephone repairman things
What's the technical name for an audio test tone generator, and where can I find one? WHo make them? |
my B16 is very quiet. Once you get it calibrated, I think you will be very happy with it.
Here's a tt-15 currently on ebay. http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7310667558
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 Last edited by Beck; 03-28-2005 at 23:08.. |
Kool. One more question - the instructions in that link up there -- what operating level would that set the machine to? (+3dB, +5dB, +6dB?) The only dB level that I could find thorugh the entire instructions was +1dB, not sure.....
Also, it frequently mentions the use of an external level meter. I have a mixer w/ analog meters. Could I hook it into my mixer's Ext in, and set the meter to monitor the Ext in, and get an accurate level reading? Thank you so much for your help. I really appreciate it. -callie- |
#12
and........What fluxitivity of calibration tape should I use? +3dB, or Those calibration instructions don't say so. It says to play back the calibration tape, and adjust until the meter reads 0dB.
Depending on if the calibration tape is a +3dB tape, or a +6dB tape, uh, that could be the difference between life and death. -callie- |
#13
Technically you could use a vu meter on a mixer for "close enough" but you would have to be confident that it is calibrated correctly (not usually). Also, depending on the brand of mixer the meter they use could be good quality or not so good. Calibrating a mixer to a tape machine is a separate operation to be completed after the tape deck is set to spec. The + 1dB in the B-16 link is referring to the acceptable range of deviation (plus or minus 1 dB). It's not referring to tape operating level. An output of 1 kHz @ -10 dBv will read about 316 mV on a multimeter and should show 0 dB on the B-16 bar graph meter. I'm not sure what the flux level is on the B-16. The E-16 was 320 nWb/m or +5. The A-8 was 250 nWb/m or +3, but I can't say for sure about the B-16. 456 will work either way. -Tim
«:: «::B::» «::E::» «::C::» «::K::» ::» "Where in the hell are the red M&M's?" ~My Lil' Sister, 1976 Last edited by Beck; 03-29-2005 at 17:36.. |
#14
I e-mailed Fostex, and they said that the B-16D requires a test tape of a 320 nWb/m (+5dB) fluxitivity.
That being said, MRL's standard tapes only come in +3 and +6, so I'm just gonna get a +6 one, and adjust accordingly. -callie- |
#15
I Feel Like An Idiot
Turns out the NR switch on the back was set to EXT. I flipped it to INT, and viola. Virtually noiseless recordings. Though I feel like kicking myself in the ass 50 times, i'm still RELIEVED!!!
I'm still gonna calibrate it, though. I've already ordered a multimeter and a cal tape. |
#16
ack!!! I had thought of that, but didn't want to say anything.
Amazing how quiet they are, isn't it! These guys here are always knocking them, but I think they are great! BTW, I also own a 2inch Otari, and an MS16. So I'm not biased. I just think in the 1/2" format, Fostex got it right. |
#17
#18
OK, so after a long hiatus of SCHOOL, I finally started to calibrate this thing.
Turns out there's several calibration tweakers right behind the meters, but the manual mentions even more tweakers, and voltage test points, at which point i was like, what the crap? where are they? So, I started slicing and dicing the thing, and FINALLY found them. They're in the most inconvenient spot -- ON THE BOTTOM. SO, for those of you who own one of these suckers, here's how to start calibrating them -- Remove the front meter bridge cover, and the control panel with an allen wrench. THey'll dangle, but it's ok. This'll unveil about half of the tweakers. Then, turn the machine on it's side (or upside down, i guess either way will work), and be sure to align the front face of it on the edge of a desk, CAREFULLY, so that you can still play a tape on the front of it, without the flanges rubbing against anything. NOW, remove the bottom 4 rubber bumpers, and take off the bottom cover. VIOLA. there they are. Each track card is right there, you've got a few more tweakers, and all of those test points the manual talks about. That's as far as I've gotten so far. Now I've gotta get some alligator clips for my multimeter, cuz these probes won't cut it. -callie- |
#19
did you make any progress with that?
I have an E-16 that I half assed calibrated. I also noticed that with 456 hiss is horrible...with GP9 you dont even need the dobly. I am still trying to figure out which is better. |
#20
thanks for this thread guys. i'm going to be borrowing one of these machines for a few months to work on my lo-fi 'masterpiece'. everything slamming to the tape and work it out in the mix. kind of like the high water marks sound.
i hope there's enough saturation to achieve this. |
#21
eh...
I dunno about SLAMMING THE TAPE on these machines. The Dolby C kinda keeps everything secure from saturation. You'll have to crank something calibration wise to even come close to achieving tape saturation. If the thing's still factory calibrated, then it's running at +5. If you use a +3 level tape like 406 or 407, you might get some grungy saturation. lol. Could be a good thing or a bad thing. Good luck w/ that.
I got some test clip adapters, but I will let you know when I actually start to tweak this machine. (Finals week. not enough time )And about using 499/GP9, Not too sure about that. I know that the Fostex electronics aren't meant to be cranked too high, and using 499 tape on a +5 operating level.........yeah it'll give you less noise in the tracks, but seems to me that the sound quality of the actual recording would suffer. You may try calibrating it up to +8, but that may sound terrible. I dunno. |
#22
I've Calibrated the Dolby Encode (aka Repro level). Since the manual stated the instructions in reference to a +5 cal tape, and I have a +6 cal tape, I set the voltage of each channel NOT at 350mV, but at 400mV, which seems like one step higher. This sound correct?
-callie- (The reason I added 50 mV, is because as I adjusted the rep level down, each increment on the bar meter seemed to be 50 mV higher, or lower, so I figured, a step up from 350 would be 400.) |
#23
Holy Crap!!!!!!!!!!!!
I think this thing's running at 30 ips. (?!?!?!) Is it supposed to be that way, or should I just tell the dang capstan to calm down?
#24
Ok, sorry for ranting, but,
Turns out, the B-16D is indeed a 30-ips-only machine. Looks like I'm just gonna have to sell the thing and get a 38, 48, 58, TSR-8, or Otari MX-5050 of some type. I cannot afford to run at 30 ips, with the cost of tape and all. I don't have the cash for 16 tracks of outboard gear anyway, so, 8 tracks will do. I just wanna get rolling, somehow. Thanks for all your guys's help. And if anybody wants this thing, just gimme a shout. Comes w/ takeup reel. my email is lockhart109@yahoo.com Last edited by Muckelroy; 05-09-2005 at 23:13.. |
#25
that sux dude. good luck!
| Fostex MR-8 | Bobby Vanzandt | Fostex Forum | 61 | 11-04-2004 07:30 |
| Fostex 812 | Neil Ogilvie | Fostex Forum | 6 | 05-13-2003 03:31 |
| First Experience with Fostex: Not Good | donovan1968 | Fostex Forum | 6 | 03-17-2003 20:43 |
| Recieved The Fostex VF-160 CDR Need Advice!!! | Axe4Yahweh | Fostex Forum | 7 | 02-16-2003 17:16 |
| Fostex VF-16 into Audiophile? | Johnalex | Digital Recording & Computers | 0 | 12-04-2002 22:34 |
