Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 03-28-2005
bruuen bruuen is offline
Junior Member
bruuen is on a distinguished road
Midi Input Problem, Plz Help!
hi guys, i'd appreciate your help greatly on this...i have a m-audio radium controller...and when using the keyboard with either cubase or reason, for the first 10 seconds, i'll see the input meter moving as i'm playing, and then it just completely stops and i can't play my keyboard anymore...the audio still works if i were to draw in the notes though. Cubase and Reason still recognize the Radium controller to be the active controller though, so i'm not sure why this problem is happening...thank you so much for any replies!
Old 03-29-2005
Atterion Atterion is offline
The Dark Knight
Atterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond reputeAtterion has a reputation beyond repute
Are you using legitimate software??? No one want's to waste time trying to figure this out if it is ultimately going to be the fault of cracked software. But, I wouldn't necassarily suspect the software as, more than one program seems to exhibit the problem. Try reinstalling the driver's. Also check to be sure that the Radium is plugged into a USB Root Port and not a USB extension hub. I found that hubs create power problems for the Radiums and Korg MicroKontrols.
Torment, Violent Aggression,
Systematic State of Oppression.
The Heretics, All Swing From The trees,
Cast To Hell, With Their Disease. DARKENED
Old 03-29-2005
Junior Member
thanks for the reply...by extention, do you mean the extra usb ports in the front? thats what i have it hooked up to, so i'll try the ports on the back...its not an illigitimate software problem...right now i'm using my old casio keyboard with midi cables as backup and its working fine...so its definately the radium at fault here.
edit: i just reconnected but no go...damnit, i think theres a defect in the controller...so annoying, i've only had it over a year now.
Midi problem, I'm dead in the water. Rain MIDI Mania 10 06-07-2004 19:45
i'm having a midi sync problem... roostmusic Cakewalk / Sonar Forum 21 02-14-2003 02:22
Midi and Audio synconization problem! PLZ HELP ! jumpingflash MIDI Mania 1 10-17-2002 14:02
No midi input & no output thru monitors syncop8shun Cubase User Forum 3 06-15-2002 21:14
Cubasis and Hubi's MIDI Loopback...problem! Cazzbar MIDI Mania 0 11-21-2000 21:56
