Old 03-27-2005
Phoenix5891's Avatar
Phoenix5891 Phoenix5891 is offline
Junior Member
Phoenix5891 is on a distinguished road
Halion 3.0 For Sale!
Only- 250
retail- $399.99
You can get
Session Strings for only 75 bucks extra (A 100 dollar Value!)
Free Shipping
HALion 3 is the latest version of Steinberg’s award-winning software sampler. Over 50 new features in HALion 3 include 27 added effects, new sound management tools and RAMSave technology. The sleek new user interface and expanded routing functions add even more flexibility to the HALion experience.
Since its launch in 2001, HALion has been pushing back boundaries in virtual samplers. HALion 3 is no exception: over 50 new features ensure that HALion stays where it always has been: at the forefront of digital audio technology. This latest version expands existing HALion capabilities to new levels of accessibility and flexibility, creating a virtual sampler environment that not only lets your creativity flourish, but lets you work more productively and efficiently than ever before. Building on the outstanding surround-capable HALion 2.0 sampling engine with support for up to 32-bit floating point files, HALion 3 adds even more new capabilities. A new output routing system allows you to create and configure the audio outputs; only the outputs you need will be routed directly to the host VST mixer. The sleek new user interface is not only easy on the eyes but has been restructured to keep switching between the 3 different HALion views to a minimum.
New features in HALion 3
New file browser with drag and drop support, favorites system, sound categorization and database indexing. An impressive set of powerful new sound management tools gives you a clear overview over all your sound files. The intuitive sound categories system lets you group related sounds, making it easy to find them quickly!
Dazzling new Insert and Send Effects section. Twenty-seven quality effects encompass just about any effect requirement. They can be applied to individual samples, sample groups or entire programs. Effect sends can be sent to HALion's internal FX section or even directly to the VST mixer to share plug-in resources between the host and HALion.
HALion 3 now offers RAMSave, a new feature created to keep in check the RAM resources needed by even the most extensive sample instruments, resulting in low RAM usage and faster project load and save times; a boon for pro users using large, intricate sampled instruments such as big orchestral patches or large drum kits.
Alternate mode -- adds a range of functions, including playing a different sample with each new Note On message, introducing more spontaneity and feeling, especially useful for realistic drum-sounds or string bow up/down action.
Even more file formats -- HALion 3 adds support for Kurzweil and Kontakt sounds as well as for the Zero-X BeatCreator and BeatQuantizer Groove-Slice formats. You can find a 15 day limited Demo version of ZeroX BeatQuantizer in the 3rd party Demo folder on the DVD.
Sleek and clean user interface -- HALion explains its intuitive GUI with the new and improved ToolTip Help. Presets let you recall frequently used settings for envelopes, modulations and FX. Many views can be opened in separate windows.
Features
-- Up to 32 Bit / 384 kHz file support
-- 256 voices per instance, several instances loadable simultaneously
-- 16-way multi-timbral with an individual editor for program selection
-- 128 programs per instance, unlimited layers per program
-- Full individual parameter set for each sample if required, ideal for drum sounds
-- Notch/High Pass/Low Pass/Band Pass 12 dB and 24 dB filters as well as fantastic sounding Waldorf filters, and Fatness function for overdrive filter sounds
-- 2 synchronize-able envelopes with up to 32 freely editable points, intuitive handling
-- 32-stage STEP envelope as free modulation source and 2 LFOs, syncnronizable to the host application
-- Keyzone Editor for quick mapping of keyzones, samples, sample layers and velocity values with drag'n'drop support and several automapping modes
-- Up to 256 freely configurable outputs per instance
-- Reverb, Phaser, Talkbox, Delays, EQs, BitCrusher, AutoWahWah and much more (27 effects total)
-- Insert effects can be applied to individual samples, sample groups or entire programs
-- Effects sends can be sent to the HALion internal Send effects or directly to the VST mixer through configurable outputs to share plug-in resources between the Host and HALion
-- Integrated Waveloop Editor with crossfade, snap to zero, loop, release loop, loop tuning settings
-- Total recall: all samples are saved with your song, including the respective settings
-- Sample-accurate timing and automation thanks to perfect VST integration
-- Archive function, transfer of entire projects to other computers with zero hassle
-- RAMSave technology offers lower RAM needs, speeding project loading and saving
-- Import formats: AKAI, E-MU, Roland, Kurzweil, GIGA, Kontakt, EXS24, SF2, LM4, LM4 MkII, REX, ZeroX BeatCreator, WAV, AIF, SD II (Mac only), ISO & Nero Disc Image, Toast CD-Image
-- Supports VST, DXi and AU formats
Email-PhoenixProductions@Gmail.com
..:!!:..Phoenix Productions ..:!!:..
Phoenix Productions
MY Space
Old 03-30-2005
Junior Member
Still Available
Phoenix Productions
MY Space
Halion or Drum sampling tutorials? recedo Drums and Percussion 0 03-20-2004 07:09
SX, Halion and the busses in the track mixer zardoz Cubase User Forum 1 10-07-2003 12:12
Halion don't record on Sx. frank_1 Cubase User Forum 1 01-01-2003 18:33
halion went wrong jimmychan Cubase User Forum 2 09-07-2002 05:48
The 24-bit challenge Ethan Winer Digital Recording & Computers 142 04-14-2002 10:07
