Old 03-20-2005
Decay Decay is offline
Junior Member
Decay is just really niceDecay is just really niceDecay is just really niceDecay is just really niceDecay is just really nice
M-AUDIO BX8 vs BX5
I had finally decided on investing in the M-AUDIO BX5s after reading many positive reviews and remarks on this forum, but then, as I'm about to place my order, I stumble upon a nice deal offering the BX8s for a price within in my budget.
I have read a lot of nice things about the BX5s on this forum. How does the BX8s compare? Are they any good? My main concern with the BX5s were the lack of bass response I had been reading about on the forum.
Thanks in advance
Old 03-22-2005
junplugged's Avatar
junplugged junplugged is offline
Busy Writing/Producing...
junplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond reputejunplugged has a reputation beyond repute
I like the bx5's, I heard the 8's in the store and I thought it was just way too much bass. The stuff I was listening to thru them seemed way off from how I was used to hearing it. So it's totally subjective. You really need to go hear them first. The 8's are also huge compared to the 5's.
I knew what I could adjust to and it w/ the cd I used, I knew it wouldn't work for me to learn the 8's. It took long enough for me to learn the 5's. I'm also very close to them and didn't need any additional power.
Old 03-22-2005
Massive Master's Avatar
Massive Master Massive Master is offline
MASSIVE Mastering, LLC
Location: Chicago area, probably looking for more coffee.
Massive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond reputeMassive Master has a reputation beyond repute
I think the BX8's are at least BX3 better than the BX5's...
Seriously - The BX8's are some pretty cool boxes - Very tunable also. Bitch to break in, though... Ran them for days straight before they started to feel right.
Nice crankability factor also.
John Scrip - MASSIVE Mastering
Spoon-feed a newbie the answer and he'll mix for a day --
Spark his curiosity to find the answer himself and he'll mix for a lifetime...
Old 03-23-2005
jeffree jeffree is offline
1K Silver Member
jeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond reputejeffree has a reputation beyond repute
Decay, I always keep an eye on M-Audio BX reviews in the many mags I read... Future Music, EM, SOS, etc. I can summarize very generally what I've seen: these monitors sound quite different from each other, so you really should try to hear them.
* Some overlapping points of the agreement I've read during the past year:
* Both models have the same adaptability switches, including HPF settings for use with a sub.
* Both models have slightly aggressive upper-mids/highs.
* The BX5s are quite accurate but lacking in low end. Adding a subwoofer could be helpful for mixing lows.
* The BX8s have more low end but it's rather flabby, and the upper-mids/highs seem especially harsh to some reviewers.
In short, I've learned that the BX8s are not simply bassier versions of the BX5s. They have sometimes gotten very different reviews, even from the same mag. (One example: the recent Future Music monitor shoot-out rated the BX5s higher than the more expensive 8s.)
Try to find these and other reviews and give a listen if at all possible. The decision really is so personal, especially when different studio environments are involved.
Good luck,
J.
(Disclaimer: I'm very satisfied using the BX5s with a cheap sub and haven't actually worked with the BX8s.)
Old 03-23-2005
AussieInLondon's Avatar
AussieInLondon AussieInLondon is offline
Newbie
AussieInLondon is on a distinguished road
Thumbs up
Bought the BX5's.
Result =
Added SBX Subwoofer to fatten out the sound.
Result =
Connected all it up to an M-Audio Delta 66.
Result = WOW!
Recommendation:
If you go for the 5's get the Sub as a "must".
If you go for the 8's get the Sub as a "must".
Buy Delta 66 or better soundcard to complete setup.
Hope this helps....
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not what I meant.
Old 03-26-2005
DigitalDon DigitalDon is offline
1K Silver Member
DigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond reputeDigitalDon has a reputation beyond repute
I've had my BX8's for quite a while and like them. Must be the blue LED's. It did take some time to learn them. You can really crank them up if need be. Still wish I had a sub to go with them though. My final check is still on a pair of JBL 4311's I've had since 1979 even though they are overdue for a woofer reconing job.
DD
M Audio BX5 Speakers messed up Tifstorey Newbies 16 01-18-2005 07:17
MIDI to Audio in DP 4.5 - Techniques and Levels? RhythmRmixd MIDI Mania 2 12-27-2004 14:06
M Audio BX5 speakers Buzzing!! Tifstorey Digital Recording & Computers 9 12-22-2004 15:58
Difference between SEND and INSERT in cubase Gabriel Sousa Digital Recording & Computers 4 01-27-2003 12:48
exporting audio vs mixdown audio Waysid Cakewalk / Sonar Forum 3 02-27-2001 14:48
